When i connect my hard drive to my laptop the baloon comes up saying that usb device is unrecognized.
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    sounds like a need for a clean re installation
    President:
  • 1,257 Answers
SYMPTOMS: loadTOCNode(1, 'symptoms'When you plug a USB device into a Windows XP-based computer immediately after the computer comes out of standby (S3) or hibernate (S4), the computer may not recognize the USB device. When this issue occurs, the USB device may be listed in Device Manager as an unknown device, and you may receive the following warning message:
To work around this issue, use one of the following methods:
Method 1 loadTOCNode(2, 'workaround'); After the computer comes out of S3 or S4, wait five to ten seconds before you plug the USB device into the computer or hub.
Method 2 loadTOCNode(2, 'workaround');After the computer comes out of S3 or S4, unplug the USB device, and then plug the device back into the computer or hub.
Method 4 loadTOCNode(2, 'workaround'); Disable power management of the USB hub.
Note If you perform the following procedure, you may also reduce the battery life on a portable computer.
To disable power management on the USB hub, follow these steps: 1. Click Start, click Run, type devmgmt.msc, and then click OK. 2. Expand the Universal Serial Bus controllers node, and then follow these steps for each USB Root Hub that is listed: a. Right-click the USB Root Hub, and then click Properties. b. Click the Power Management tab. c. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.-------------------------------------------
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Posted on Apr 30, 2008
My device is unrecognized by windows vista it keeps saying I need to update the driver but this I know is built into the unit is there a fix for this?
Try uninstalling the Generic USB Hub and USB root HUB drivers listed in your computer.
Restart the computer and then try connecting the HDD once more.
Nov 11, 2011 | Fantom G-Force MegaDisk 1.0TB 7200RPM USB...
When i insert pendrive computer says unrecognized device
you might have to install usb drivers
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers
hope this helps
Oct 19, 2010 | Microsoft Computers & Internet
Unrecognize USB and has malfuntioned
OK go to device manager and totally remove and un-install the USB layer totally, right click and choose uninstall/remove... after which reboot and then windows will automatically re-install the USB layer and you can use it again.
Jan 23, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I plug my usb external hard drive into my laptop but it does not read. How can I fix it?
Have you tried changing which USB port it's hooked into. If not is there any cd (Drivers/Software) for your external / that it came with?
If not you might have to search for unrecognized hard ware. This will help with that: http://www.techmantras.com/content/finding-drivers-unrecognized-hardware-windows-system
Dec 23, 2009 | SmartDisk FireLite 40 GB Hard Drive
My sony microvault 2gb hardrive has malfuctioned
Hi, This usually means the USB controller has failed, however it can also be a damaged driver or registry entry on the computer it's connected to. Try connecting it to another PC, let me know wether or not it works. If it does we need to address the problem on your computer, if it doesn't I'll refer you to an appropriate recovery center, if the latter is the case let me know your city and country/state. I will recommend an appropriate recovery facility. Chris
Jun 04, 2009 | Sony Micro Vault Pro USD-2G (SONYUSD2G) 2...
EXT HD UNRECOGNIZED BY LAPTOP
Which operating system are you using? Windows XP or Vista?
Here is the website that you can download the driver for your external harddrive.
http://support.wdc.com/product/download.asp?modelno=WD1600JB-00FUA0+WD+&x=1&y=11
Mar 26, 2009 | Western Digital External USB 2.0 80 GB...
My hard drive and midi controller wont work with usb
When you connect a hard drive and any other USB device to a 4 port hub you have to use the external power supply all the time. You may have fried the power pins on the USB port you used to connect the 4 port hub. If you can get the hard drive to work separately on the USB port, the 4 port hub may no longer be passing power from the laptop.
Nov 09, 2017 | Vestax Vci 100 Midi Controller
Sir/Madam when i attached my external 30gb hdd via usb ide data cable with my laptop message appear "unrecognized device" how i solve this problem?
You need the driver for the device. If the HDD came with a disk you will need to install that beore hand. =) Hope this works.
Ed
Jan 31, 2009 | Toshiba (HDD2181) (hdd2181-50pk) 30 GB...
Unstopped portable harddrive unplugged, now says unrecognized.
if you want data recovery software, i can e-mail it to you.
mewms_14904@verizon.net
Mar 03, 2008 | Computers & Internet
Lacie 250 gb hard drive isn't recognized on computer
Controller got smoked when cable unplugged, take in if ya need the files off.
Nov 04, 2007 | LaCie (300728U) 250 GB Hard Drive
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
