Question about Dryers
Display reads F22, dryer shuts off after 1 minute
    Problem Solver:
  • 8 Answers
To enter the diagnostic mode, choose any selector button other than Pause/Cancel and do this little keyboard dance:
Press and hold for three seconds,
release for three seconds;
press and hold for three seconds,
press and hold for three seconds.
You’ll know you’ve entered diagnostic mode because all the indicators on the console will light up for five seconds and you’ll see the code “88” in the Estimated Time Remaining display.
the F22 Code you are getting is the exhaust block or overheat!!! DO NOT USE YOUR DRYER UNTIL YOU CLEAN THE EXHAUST OUT! this is a MAJOR fire hazard
it may also be as simple as a lose wire or something like a bad sensor but chances are that your dryer is doing what its supposed to so that you dont have a fire :)
~lee
admin @ WhyPayForHelp.org
Posted on Apr 30, 2008
Maytag dryer 3000 fault code f22
Replace the door latch. Fault code F22 is for the door latch.
Oct 12, 2015 | Maytag Dryers
Dryer shuts after one minute
If it heats then you're getting 240 to the dryer. Take off the vent hose and look for a lint build up in the hose and where it connects to the house. Restriction will cause the dryer to shut off the heat to avoid a fire.
Oct 20, 2014 | Whirlpool Dryers
Error f22
Open exhaust thermistor at room temp should read 11.5-13.5 k-ohms
Jan 22, 2014 | Whirlpool WED6200S Electric Dryer
Maytag front load washer, MHW 3000 series, f22 error message
This is a problem with the door not locking shut. Maytag have an ecellent technical assistance page on this problem with diagrams and stuff. Go to:
http://maytag.custhelp.com/app/answers/detail/a_id/2889/~/display-shows-f22-or-fdl---front-load-washer
and take a look
Jun 30, 2011 | Maytag Washing Machines
DRYER DISPLAYS CODE F22. What does this mean?
"F22" is a door lock issue Press the "Stop" button twice to cancel the cycle if "F22" shows. Check that the washer door is firmly shut--open it and shut it and try again. Make sure there aren't items blocking the closing of the door. Don't overload the basket. Try the cycle again.
Nov 25, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Maytag 3000 series dryer fault code f22. what does it mean? dryer is just over a year old so i think i'm outside warranty.
F22 is an exhaust blockage. Machine shuts off to prevent overheating and causing a fire. Check the exhaust in the back for blockage. Also clean lint screen before each load to decrease the chance of exhaust blockage
Oct 03, 2010 | Maytag Dryers
Error code F22 after 1 minute of drying with brand new Maytag 3000 Series dryer
If it is new, you should call maytag to repair under warranty terms. The unit could be defective.
1 (800) 344-1274 U.S.
1 (800) 688-2002 Canada
Nov 12, 2009 | Maytag MEDE300V Dryer
DISPLAY SAYS "PF"
HI, there may have been a power surge that shut this unit down or, the junction box may be shorting the power sector. this will damage the main control in this case. i recommend shutting the power off by, pulling the unit plug from the wall socket or, shut the circuit breaker off. let the unit sit for 5 minutes without any power. this will reset the logic chip.
Power the unit back up after this 5 minute wait to see if the reset worked. if the PF is still present, this will confirm a main control fault. replace the control in this case.
**check the power cord junction point for worn connections.
Jul 18, 2009 | Maytag Neptune MDE5500AY Electric Dryer
F-22 problem
F22 is a problem with the touch pad, check connections to the touch pad if ok replace touch pad assembly
Jan 11, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer HE2
my kenmore he2 gas dryer runs for 2 or 3 minutes the shuts off, flashing an f22 error code
May 05, 2008 | Kenmore 85871 Electric Dryer
Dryers Logo
468 people viewed this question
Top Dryers Experts
