Question about Sharp AR-5320 Black and White Copier
NO PROBLAME JUST A QUESTION
HOW MANY COPYS CAN A TONER PRINT ?
  • 29 Answers
15,000.00 copy for every cartrige of ar-5320
Posted on May 02, 2008
  • Sharp Expert
  • 1,326 Answers
That all depends on the amount of toner coverage on the copies you make? The companies gauge the number of copies per toner on only 6% coverage on each page. About one small paragraph, any more the less the yield. On average about 2k -2.5k per toner give or take.
Posted on Apr 30, 2008
Low quality prinding copys
add new toner and do a drum refresh should fix it
Jan 31, 2014 | Kyocera TASKalfa 180 Copier
Wont print copys
Try performing a scan. Probably the scanner or the scanner flat cable is damaged.
Apr 11, 2012 | HP InkJet Office Equipment & Supplies
I have a new Hl 2140 and haven´t printed more than 100 copys but now the toner light is on and the printer refuses to print
Tip the toner cartridge from end to end to redistribute the toner. You will get more mileage out of it, if it is simply a low toner issue.
Apr 21, 2010 | Brother HL 2140 Laser Printer
Brothers MFC 7420 It says Toner Life End on my LDC and I still get great copys. I have had this issue before and I think this machine is programed to have me purchase toner before I need to.
The MFC7420 has sensors that sense when the toner is low. It lets you know in time to purchase another cartridge before you totally run out. If you can get one same day I wouldn't purchase one until the printer pages start fading.
Oct 08, 2009 | Brother MFC 7420 All-In-One Laser Printer
Lexmark model X4580. Prints 3 copys every time .
When you want to print, the Print window appears showing your printer, there is a box where you can select the number de copies.
Hope it helps
Sep 05, 2009 | Lexmark Office Equipment & Supplies
Smudges on paper and then when it does copy, ink is light.
hi,check copy cartridge or clean corotron wire.try to increase toner.send me result.
thank you.
May 25, 2009 | Sharp AR-5320 Black and White Copier
Black page
Main charge unit is shorting out.
Pull the main charge unit out of machine.
Take cleaner (included with toner) and clean.
--Look at front and rear for toner build -up on the charge grid.
This build -up causes a short.
After cleaning, reinstall and run.
Oct 21, 2008 | Copystar - CS-3035 Printer
Print problem
Stop print before fuser to see if error occurs with print or fusering system?
Make sure you have cleaned carona on drum and returned slider to home position
Check if print ok or if it is just copys?... if just copy clean scanner glass slit
You are using OEM drum and toner arn't you?
There is one last alternative but I won't bother to descibe till I get some more info from you
Dec 29, 2007 | Brother MFC-8840DN (Bundle) All-In-One...
Color
toner settled ... I thinking funny now... take it to a paint shop and have it shaken,
but really all your cartridges need shaking just open the door a few times and it will cycle your cartridges a few times, still problems ...rubber belts , rollers harden when set-up, ever seen an old rubber band? try streching it.
I would try to print like 50 copys of something to see if it shakes the cob webs.
Oct 24, 2007 | Konica Minolta magicolor 2300DL Laser...
Black pages when making a copy or printing something
Have you tried both drum and toner supplies? cause it sounds like a drum fault, if you have tried a new drum and toner, and it is doing it when printing internal reports, receiving fax's and copying then you have a tecnical issue to do with charge and this would likely render machine unecomical to repair (unless you can find a bad contact with drum on machine). If it receives faxs clearly but copys black then it is different issue (ie optics).
Oct 16, 2007 | Brother IntelliFax-2820 Laser Fax
Sharp AR-5320 Black and White Copier Logo
121 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
