Question about Vodavi 30-Button XTS Telephone
Oncoming phone calls from internal ext go directly to speakerphone instead of ringing
There is some magic button that keeps getting pressed to activate this feature.
Thanks!
  • bob collins
    bob collins May 11, 2010
    Is this still unsolved. I am a certified Vodavi tech
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
If this is on just your extension, dial 640 without picking up the handset. The phone should beep twice. If not, hang up the phone and let me know. If this is helpful, please post as such.
Posted on Apr 03, 2009
Toshiba DKT2020-SD
Do not press the conf/transfer key.
press the intercom button first.
Then press the day key or dial ext number.
Tony
732.720.9369
May 20, 2014 | Toshiba DKT-2020 Corded Phone
I have 7 Nortel t7316E handsets with only one ringing on all calls received I need to program another phone to ring also so I can have another person answer phones from another extension.
You will need to change the programming for the ext that you want to have the lines appearing on.
Enter programming - Feature **266344
PW - 266344
Press the show key - (top right arroe that is lit on the display)
Enter the ext # you want to change
this will bring you to line appearance press top r arrow
line assignment press top right arrow
show line - enter 001,002 or whatever line(s) you want to ring.
press the change softkey for each line to appear and ring instead of unassigned. Press the next (bottom r arrow) to go through each line after entering 001....
then release.
*** Make sure the sets you change are not forwarded to voicemail after a certain amount of rings otherwise all calls ringing on the newly programmed set will go to that persons voicemail.
Mar 10, 2014 | Nortel Norstar 16-Line PBX Speakerphone
All extensions ring on oncoming call on NEC Dterm series i
.. I don't have a solution, I need a solution.
NEC Dterm Series I, through internal calls my phone flashes notifying me that I have a call coming through but it doesnt ring. I have tried the volume key ^, that didn't work. Can anyone help me?
Aug 27, 2012 | NEC Dterm DTP-2DT-1 Phone
Hi I am working at the Switchboard. I have a Panasonic KX-T7730 that is seven years old. Every office has an extension code and a name. I want to change the display names of the extensions as it still...
This has to be done on Ext 101, or whichever phone is the programming phone. Press program *#1234. Then enter in 004. Press Speakerphone. It should be asking for a jack number. You can press speakerphone again to go to the first ext. Spell out the name using the keypad (2 is A, B and C and so on). When done press the autodial/store button. Then you can press speakerphone to go to the next phone. To get out of programming just pick up and hang up your phone or press the program button.
Aug 30, 2011 | Panasonic KX-T7730 Corded Phone
I have Norstar M7310, we have 6phones in our office and question on one of phone ext. 241. when calling ext.241 all phones are ring, but when calling other ext.phone is okay will only that phone rings. ...
Sounds like extension has put the phone on transfer. You can try these steps on the Extension 241 phone and see if it will correct the issue. 1. Press the Feature button, then * 2
2. Push the button you want to program
3. Display will read "Intercom #:__"
4. Enter the extension number
Jan 07, 2011 | NorStar M7310 Corded Phone
KX-TA308 in Malaysia, I have assigned Ext110 as operatior, when I call from internal using 0, ext.110 rings, but when incoming call pressing 0 for Operator, it is not ringing and it keeps saying that...
There is a second program that assigns digits to "0". You found the one in the phone system, but not the AA/VM. It's probably still trying to dial 101. Make it dial either "0" or 110.
Carl
Dec 28, 2010 | Panasonic KX-TA308 Phone
I have Cisco 7060 phone and using corded Plantronics headset plugged in to the headset port. I experience problem that speakerphone has priority over the headset. When I enter the phone number on keypad...
There is, but these settings are setup in Call Manager, or Call Manager Express. I would see your systems admin to set the default priorities.
Aug 27, 2010 | Cisco 7960 IP Phone
Hello.. We have the parter-18D phone system. one of the phone rings when there is an incoming call, but it shouldn't, since this is not the main phone Ext 10. How can I program this phone to ring only...
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
May 06, 2010 | Lucent PARTNER18 Corded Phone
Transfer
Do you mean send the call to another phone?
Make sure the line is not on hold (push the caller's line) then push Cnf/Trn, dial the extension you want the call to go to, then hang up.
The person you're sending to will receive that call on their speakerphone button and it will ring in a different tone.
Jan 13, 2009 | Toshiba DKT-2010H Corded Phone
Vodavi 30-Button XTS Telephone Logo
226 people viewed this question
Top Vodavi Lands Phones Experts
Oloyede Monsuru
ray gallant
vince
Are you a Vodavi Lands Phone Expert? Answer questions, earn points and help others
