Question about Palm Z22 Handheld
Palm z22 how to reset password if forgotten
  • 1 more comment
  • Anonymous Mar 15, 2009
    i forgot my password and cant get it to reset with no password
  • sugarpie9 Mar 15, 2009
  • bob collins
    bob collins May 11, 2010
    Has this one been solved
  • 689 Answers
Use paperclip like tool to press reset button hole and same time hold power button once you release the power button it will give you confirmation for full reset
Posted on Aug 23, 2009
4 Suggested Answers
SOURCE: how to do a hard reset on a palm z22?
Hi here are the steps but ensure to backup data before you make a hard reset
Press and hold the power button
While holding the power button, use the tip of the stylus (or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld.
Wait for the Palm Powered™logo to appear, and then release the power button.
When you see the message that warns you about erasing all of the info on your handheld, do one of the following:• Press Up on the 5-way navigator to finish the reset and show the touchscreen.• Press any other button to do a soft reset.
When prompted, tap to align the screen, and then select the language you want to use on your handheld. A screen appears showing the Palm logo and a progress bar.
When the Welcome screenappears, the hard reset iscomplete
Hope this helps and do let me know
Posted on Mar 07, 2009
SOURCE: Can't reset my password on my Palm Z22
GO TO PREFERENCES AND CLICK ON SECURITY AND UNASSIGN YOUR PASSWORD AND THEN TRY TO SYNC AGAIN. THIS FIXED MY PROBLEM.
Posted on Sep 29, 2009
deb1611
  • 3 Answers
SOURCE: My Palm Z22 won't turn on. If I do a hard reset
It absolutely won't, you don't have to worry. I've done it several times, and I know I was really nervous at first, but it's fine.
Posted on Jan 01, 2010
I bought a used Palm z22, the previous owner didn't clear out their password. How can I clear it so I can use
Press and hold the power button through out.
While holding the power button use the stylus or similar item to press the reset button on the back of the Z22.
Keep the power button pressed until you see the Palm logo appear.
Let go and hopefully this will reset everything, although it is not guaranteed to reset the password.
If it all works and resets everything, you should be able to set the Z22 as you want from now.
Jan 26, 2015 | Palm Computers & Internet
How do I reset my palm z22 to factory settings?
If you've set a password on your handheld, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
  1. On your handheld, launch the Prefs application. Under General, select Security.
  2. If the Password box says "Unassigned," tap the box and create a password for your handheld.
  3. Once the password has been set, remove the stylus. Disconnect your handheld from the AC charger, if connected.
  4. On your handheld, hold down the Power button.
  5. While holding down the Power button, use the stylus to press the RESET button on the back of your handheld.
  6. While still holding Power button, the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
    887_palmlogo_progressbar.gif spacer.gif 887_poweredcircle.gif Keep holding the Power button during this screen. spacer.gif When you see this screen, you can release the Power button.
  7. A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
  8. You'll see a series of Palm logo screens, then a prompt to tap onscreen targets. The Factory Reset is complete.
Apr 15, 2010 | Palm Z22 Handheld
If you have forgotten your password you should be able to use the password hint to figure out what it is. You can try a soft reset to see if that will clear the password but I am pretty sure this won't help. To do a soft reset use the tip of the stylus or something pointed like a paper clip and inset it in the hole on the back of your palm pilot. This will make the unit reset it's self. If this doesn't help then you must preform a Hard rest to continuing using your hand held. You need to make sure that you have all your information backed up on your computer as a hard reset will erase everything on your hand held. Here are the steps to do a hard reset:
1. Press and hold the power button.
2. While holding the power button, use the tip of the stylus ( or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld.
3. Wait for the Palm Powered logo to appear, and then release the power button.
4. When you see the message that warns you about erasing all of the info on your handheld do one of the following:
a) Press UP on the 5 way navigator button on the bottom of your handheld to finish the reset and show the touch screen.
b) Press any other button to do a soft reset.
5. When prompted , tap to align the screen, and then set the language you want to use on your handheld. A screen appears showing the Palm logo and a progress bar. From there continue to set up your Palm and then do a hot sync. You should be able to reset a password if you want one. Best wishes....Hope this helps.
Aug 27, 2009 | Palm Z22 Handheld
Forgot password can't hotsync z22
The first thing I would do would be to do a hard reset and then you should be able to hotsync it. I am sending you a link to the palm support for your z22. At the bottom of the page is a link for free chat. I have used this myself and I was able to get my problem solved in a few short minutes. Hope this helps. Gotta love that palm.
http://kb.palm.com/wps/portal/kb/na/zire/z22/unlocked/supportservices/page_en.html
Aug 21, 2009 | Palm Z22 Handheld
Lost password on z22 how can i reset.
Turn unit off. Press soft reset. Holding it down, turn it bsck on.
Aug 07, 2009 | Palm Z22 Handheld
I have fogotten the password,how do i unlock the palm z22
mmm.. press reset with the edge of your stylus and center joystick button together at the same time, for about 5 seconds. that action will erase all data and restore your device to factory settings.
Gery
www.nextlab.co.il
Jul 29, 2009 | Palm Z22 Handheld
Password
There is no recovering Passwors with Palm, as far as I know.
Do a hotsync on your computer, and hold the power button while you poke a toothpick into the reset hole on the back.
The Palm will reset to default settings.
A hotsync from the computer will restore your saved data.
Good luck with that.
Jun 24, 2009 | Palm Z22 Handheld
Touch screen on Palm Z22 does not respond
The Data on your Z22 is rock-solid safe, but unlike the answer that states to do a RESET- DO NOT ! The touch screen problem has nothing to do with resetting, it is a failure of the soft plastic top layer of the touch screen. There is a tiny, remote possibility that the logic circuits are out of sync and the touchscreen really is mixed up in a software state, and a SOFT RESET may reset the touch screen, but this is almost unheard of ( but does happen).
I have an entire page on the Z22 and how to maintain, repair and interface it. It is at:
kidbots.com/WEBADD/Z22_PALM_PILOT/Z22_PALM_PILOT.html
I would suggest trying a few tricks listed on my web page, and see if you can get the screen to work again. It is IMPERATIVE to get a hard plastic cover over the screen to keep it working!
Please read over the information on the Z22 page.
good luck
robin dusty graves
Z22 PALM PILOT touch-screen-palm-z22-not-respond-ngl0e1lc0ft3j10pmz4xzklk-3-0.jpg touch-screen-palm-z22-not-respond-ngl0e1lc0ft3j10pmz4xzklk-3-1.jpg touch-screen-palm-z22-not-respond-ngl0e1lc0ft3j10pmz4xzklk-3-3.jpg touch-screen-palm-z22-not-respond-ngl0e1lc0ft3j10pmz4xzklk-3-6.jpg
May 27, 2009 | Palm Z22 Handheld
Help me please! forgotten password
there should be an option for Fogotten Password/Lost password below where you enter your password.
Apr 22, 2008 | Palm Z22 Handheld
Palm Z22 Handheld Logo
145 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
