Question about Bose & Wave& Music System
Denon udcm m7 cd player often reads ERR on play and eject
My denon udcm m7 personal component system cd player often gives an error message (ERR) when I hit play or eject on all three disc. I have to keep turing it off and trying again before it actually, randomly plays or ejects. Since Denon no longer has parts for this system, before I pay for a service center diagnosis, does anyone know what this might be? Has been doing it since I got it (refurbished) in 2000, but doing it more so now. OR does anyone have a replacement I can purchase?
Thanks, M in So Cal
  • 2 more comments
  • mssmft Apr 29, 2008
    Also, does anyone know the difference between the UDCM-M7 system and the DMM-M7 system. Is there another model CD player I can substitute for the UDCM (3 cd changer) with the rest of the components being UDCM?
    Thanks again.
  • mssmft Apr 30, 2008
    Thank you, Jerry. Will look at the link and figure out if I'm up to cleaning it myself. However, As this was a problem very early on and has gotten worse, I don't know if it is just cleaning.
    this is an older player, so Denon doesn't support it anymore - doesn't even have parts. The problem is finding anything equivalent in size to replace it. A lot of people love this player because of its size and sound, which is why I am considering fixing it.
  • Anonymous Jun 21, 2008
    have the problem with my udcm-m7...none the 3 cd doors will open and the ERR message present.
    tried power on/power off, and it sounds like i need to have the doors open before i attempt the laser clean solution?
  • paul4535 Mar 05, 2009
    Turn on but system reads err but doesn't load, unload or play cds.
    Genius:
  • 1,689 Answers
Try cleaning the laser first. Take care, because it is delicate.
Some instructions of how to clean a CD laser:
http://www.wikihow.com/Clean-a-CD-Player
If the cleaning does not fix the fault, it is possible that the laser is weak, or there are some problems in the electronics in the CD player. This is not something you will be able to service yourself, unless you are properly trained, have experience, and have the proper setup to perform CD player servicing.
In most cases these CD players are not cost effective to service. You can contact the orignal manufacture for details or any recomendations.
Jerry G.
Posted on Apr 29, 2008
  • Jerry Greenberg
    Jerry Greenberg Apr 30, 2008
    At this point you have nothing to lose by trying to clean the laser lens yourself.
    Your best reliability would be to send the unit out to a service shop that has a tech who is experienced at servicing CD players in general. He may be able to service the unit for you if it is a fault where generic parts can be used if required.
    If the laser is a little weak, it may be possible for the tech to increase the bias drive to the laser emitter if your model has such an adjustment. He should use a laser test meter to make sure that the emission is kept in spec. If the laser is set too strong, it will have too much reflection back from the disk media. Also, increasing the laser drive accelerates the wear factor of the laser. This may get you some more hours out of the laser.
    If the tecch is experienced, has the instrumentation, and has the service manual for your player, he can try to do a full re-alignment of the electronics and mechanical tracking for the laser. This may also get some more life out of the player. If he increases the laser drive bias he may have to go through this process anyways.
    _________________________________
    An explanation about audio equipment:
    Over the last number of years CD players have been greatly improved in their performance.
    As for sound quality, any good audio equipment should not have any distortion that can be heard. In high end equipment there should not be any difference in the sound characteristics or quality between devices. This is what attributes to the accuracy of the device. In quality audio equipment, the output should be accurate to the sound of the recorded material without altering it in any way.
    At a reasonable cost, older CD players were not as accurate as the ones of today for their reproduction. To have high accuracy the cost was too high for the average consumer.
    I have not done many repairs on the model series you have, but from memory I can tell you that the accuracy of a medium priced player in the audio file level of players the accuracy will be better. The distortion is lower, and the D/A decoding is more accurate for the cost. The internal computing is faster, and they have much improved design.
    If you go to a good audio equipment store, you should be able to easily find a good CD player that can outperform the one that you have. As for the physical size this is another issue. Good CD players are still expensive.
    A good player will outperform the general consumer types that you see in shopping center stores or at regular retailers. If you want something of good performance you should be shopping at an audio file store.
    If you want the best possible, you should consider going to a professional distributor that supplies professional audio equipment for recording studio and broadcast applications. This level of equipment is also much better supported than general consumer products. Everything about it is constructed better, and assembled and adjusted with very high standards.
    As like anything electronic or mechanical, after a certain number of hours of use there will be failures, and required maintenance. Because of the way progress is going and the technology is changing, this will eventually force the users to have to buy new equipment. There is the eventually non availability of parts, availability of dedicated service tools, and service skills to work on particular models.
    Jerry G.
    New Friend:
I turn the machine off, then turn it on, and lightly smack the machine on the side as it's turning on. You'll hear it catch and then start without the ERR. I've been doing this for about 2 years when it gives me a ERR message and although it's cheesy and clearly not right, it works every time.
Posted on Mar 03, 2013
  • Jason Chuan Mar 03, 2013
Cd stuck in Denon CD auto changer receiver. Displays ERR. How can I get out?
As there may be other factors at play that require a more detailed explanation, I would suggest that you seek a resolution through a discussion with a qualified technician. To do this, refer to your operating manual, which should provide a telephone number for technical contact assistance. You can also go up to the manufacturer's website and make contact for advice. www.denon.com/
Mar 05, 2015 | Denon Audio Players & Recorders
2007 Honda Accord SE CD error
Just go to a auto wrecker end get a different deck for it, It will cost you less then to have it repaired,
Dec 03, 2012 | Audio Players & Recorders
I hav a clarion auto cd/stereo displaying err 6 please explain, thank you
Error 1.Battery inside CD Changer needs to be replaced.
Error 2.CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3.CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4.Connection problem. Reconnect the data cable.
Error 5.CD error message. Could not read correct data due to CD ROM.
Error 6.CD error message. Could not read data from disc because it is upside-down.
For error code 6:
Try an original purchased cd with no scratches and see if the cd player reads it. If yes then lens is dirty or tired so try using a cleaning cd(has little brushes on it). If it doesn't read with the original cd try using the cleaning cd and if no go then look at purchasing a new cd player!
Nov 01, 2010 | Car Audio & Video
Delco factory Radio/CD player,it gives an err msg.and ejects CD
The laser in the cd player may be dirty or has gone bad and can no longer read the disc.
Apr 17, 2010 | 1998 Chevrolet S-10 Pickup
How to get service manual - Denon M10 (UDCM-M10) - CD Player
I woul try to download it from a reliable site and print or see if Denon sells it
Feb 09, 2010 | Denon D-M10 CD Shelf System
Audio/CD Player
dear friend- the error code means the lazer is not reading your cd,if it is a pirate cd it might be the problem,or the lens must be cleaned.
Apr 17, 2009 | Hyundai Motor 2004 Sonata
2003 audi a6 cd player error 2
HI,THE REASON YOU ARE GETTING AN ERROR MESSAGE IS BECAUSE THE MECHANISM IS FAULTY,YOU WILL HAVE TO HAVE IT REPAIRED,ANDY
Dec 02, 2008 | 2003 Audi A6
CD will not read or play....ejects ;;ERR message flashes Help
try different KnownGood cd and if still an issue your head unit needs repair internally .(not worth it)
Nov 24, 2008 | 2000 Chevrolet Silverado
"Err" message
i had err 2 screen. removed case (about 10 screws, took just a few minutes) and found 1 disc was had been knocked out of the tray. removed all discs. replaced case. works fine again
Dec 29, 2007 | Denon DCM-280 5-Disc CD Changer
Bose & Wave& Music System Logo
2,212 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
