Question about Video Cameras
Can I hook my JVC GR-AXM230 to my computer
Can I hook my camcorder to my computer to put my old videos on DVD
Yes, you need to buy a special cable from the camcorder manufacturer.  These are usually a massive rip off for a poxy bit of cable, but it will enable you to convert tape to dvd.
Posted on Oct 06, 2008
What is the value
They seem to be selling for $50 to $75 in working condition.
Jan 18, 2015 | JVC Compact Vhs Gr-axm230 400x Digital...
I have a DVD/VCR recording device and I need to hook up my camcorder to record videos to a DVD to submit to an organization for my son to receive a service dog. I can hook up camcorder straight to TV...
To record to the DVD, connect the A/V cables from the JVC GR-D347U to the A/V In on the DVD recorder. Since the DVD already plays to the TV, you just have to keep the TV set to that input. Put a blank DVD in the recorder. Set the DVD recorder to record on from the appropriate Line In (input) with the DVD as the target recording media. To make sure that all of the devices are on and receiving the output from the camera and DVD recorder, start playback on the GR-D347U and check that it displays on the TV. Forward the tape in the camera to the point where you want to record to the DVD. Stop playback. Press REC for the DVD recorder and restart your playback. Press stop for both the DVD recorder and then the camera when the desired video segment has been played back.
See page 21 of the manual for the GR-D347U. Treat the DVD recorder as a VCR for this situation. The manual is available here: https://www.manualslib.com/manual/82266/Jvc-Gr-D347u.html?page=21#manual .
I hope this helps. Please add a comment with the details of the DVD recorder for more information on connecting the unit in this daisy chain.
(Many recorders have at least two composite video Line In inputs. That's why you need select the correct one for recording.)
May 19, 2017 | JVC GR-D347U Camcorder
I have a jvc GR-D250U mini dv camcorder, it's old and i cannot figure out how to or if I can make a CD or DVD using my computer.
Hello, well with your camera you down-load the film by cable (mostly hi fi red/blue/white to the PC, you should put a new formated DVD disk in PC and go to windows media, there you should be able to make movie.
Jun 24, 2010 | JVC GR-D250 Mini DV Digital Camcorder
Have a JVC Digital Video Camera. Model No.
hi,
this is the mecenizam problem , you must have contact authorised person to fix it, because this work needs good expiriance so please contact authorised person,
don't worry its routing problem in same model
i have been fixx like same abuot 12 so keep smiling
Aug 31, 2009 | JVC Cybercam GR-D30 Mini DV Digital...
I HAVE JVC GR-DX307 AS - how to save the video on my laptop or how to save it on dvd
Hi and welcome to FixYa,
To save the video on a computer, a firewire connections must first be established from the JVC GR-DX307 AS to the appropriate firewire port of the laptop (assuming it has one or through a PCMCIA firewire adapter card if required). In the camera, the FireWire/DV port is located beneath the mode dial on the left side of the JVC GR-DX307’s body. To access the FireWire/DV port, the LCD monitor must be first opened.
Soon as that connection is established, you can use Windows Import Video (Vista) to capture / download the videos.
Alternately, the A / V port of the camera maybe used to connect to a DVD Recorder for direct, realtime copying & burning. For the disc to be playable in another machine, it must be finalized.
Good luck and thank yu for using FixYa.
Jun 24, 2009 | JVC GR-D370 Mini DV Digital Camcorder
Hooking an Analog Camcorder up to a computer
Yes. Pinnacle makes a analog capture device that will plug into a USB 2.0 port. It's available at www.pinnaclesys.com or you can get them at any electronic store.
Dec 20, 2008 | JVC GR-AXM17U Camcorder
I need a usb cable for my jvc gr-d22u video camera
In my opinion, Firewire is the best method for transferring video to your computer from your camcorder. The JVC GR-D22 and Dell Inspiron 9200 both have firewire ports if I am not mistaken.
Dec 08, 2008 | JVC GR-D22U Camcorder
JVC GR-DVL20E
i HAVE THE SAME CAMERA AND HAVE ALWAYS CONNECTED USING A FIREWIRE LEAD WHICH I PURCHASED SEPERATELY it's under oneof the rubber flaps and is called DVOUT. You will need to purchase a firewire lead which has that small connection on one end and whatever size your firewireport connection is, on the other
Nov 24, 2008 | JVC GR-DVL20EG Mini DV Digital Camcorder
Connect old camcorder to new PC
JVC has the support page for the GR-SXM260U here: http://support.jvc.com/consumer/product.jsp?modelId=MODL027120&pathId=25&page=3&archive=true. This camcorder can be connected to a TV with the S-video connection (JVC recommends their YTU94146A S-Video cable) or two RCA connections. If you use an RCA composite cable, you use only one of the two audio connections (white) and the yellow video cable.
To connect this camcorder to a computer, you need a USB video capture device and some type of video capture software. Here are two examples: https://www.amazon.com/Diamond-Multimedia-VC500-Video-Capture/dp/B001FAE8MA and https://www.amazon.com/ION-Analog-Digital-Converter-Composite/dp/B002MT7JFQ .
I hope this helps.
Jul 05, 2017 | JVC GR-SXM260U Camcorder
Windows Vista Won't Recognize Camera
Went to device manager, imaging devices, right clicked on the indicated sub item and updated the driver.
Feb 16, 2008 | JVC GR-D90U Camcorder
Video Cameras Logo
164 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
