Question about VIA ECS PM800-M2 PM800 P4FSB 800 Supports Intel Pentium 4 Processor (REV:1.0) (ECSPM800M2V10) Motherboard
ECS PM800 Restarting?
Yep...
I have been having shut off probs as well. and yes, months after installing 2g of Ram. I also think my CPU got tweaked out. I am waiting on a 3.4ghz CPU now but, I am worried, IN the last shutdown, It shotoff while defragging? After that, I turned it back on and the monitor was blank, the machine was beeping a few times then I shut'er down and have not been able to get it back on again, I mean the machine pwrs up but, it doesnt seem to reading the drives or???
Any advice?
Thanks
  • JimmyP9 May 01, 2008
    Hi Mike...
    Thanks for the info....
    I will try that indeed....
    Whats your take though on the "Shutting Down" in midst of a defrag scenario???
    Thanks
    ~A
CLOCK  CHANGES TIME AND DATE GOES BACK TO  YEAR 2000 AFTER REBOOT
Posted on Oct 31, 2008
    President:
  • 2,351 Answers
JimmyP9, that beeping you heard was most likely memory. Remove one DIMM at a time & test on boot up (If you have more than one DIMM. You can also test you're memory.
Go to this link & download software to test you're memory.
http://www.memtest.org/
Scroll down the page. Just under the three screen shots to,
** Memtest86+ V2.01 (21/02/2008) ** (Typed in red)
Download Download - Pre-Compiled Bootable ISO (.zip)
to creat a bootable CDROM.
Or
Download Download - Pre-Compiled package for Floppy (DOS - Win) to creat a bootable floppy disk to test you're memory.
Hope you find this helpful!
Mike
Posted on May 01, 2008
  • Mike Peluso
    Mike Peluso May 02, 2008
    Hi Jimmy,
    I'm thinking there can only be a few reasons a system would shut down during defrag.
    1. Hardware issue. 2. Memory issue. 3. Board issue.
    Since you did hear a few beeps & shut her down. That in it's self could cause data corruption. I agree with (early1234), that formatting the drive is a good idea. I personally do not use windows to formatt my drives. I use Seagate's software on a bootable CD to test, set cluster size & formatt. I use nothing but Seagate serial ATA SATA's. Using windows to formatt is ok for most people. I'd still run the memtest program once you finish reformatting drive or before hand. When you get to starting up the PC & start hearing the beeps. Let it run a bit & listen for how many, short/long & or just plain loud. That will be helpful to know.
    The beeps have a story to tell.
    Let me know & again good luck.
    Mike
  • 871 Answers
Defragging uses a lot of disk drive space and memory. while you encountered a problem during the process of defrag, you may experience some data corruption after the startup, thus, your computer wont boot... only remedy for that now is to do a reformat.
Posted on Apr 30, 2008
How do i flash the boot chip and where is it seated on the pm800-m2 motherboard?
Most modern motherboards dont have removable BIOS modules. However they can be updated in the Windows. Visit the manufacturers website and download the appropriate BIOS update. Here is the link.
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=453&DetailName=Feature&MenuID=24&LanID=0
In the above picture i cannot tell you exactly which is the BIOS chip but it is surely among the three big chips near the RAM slots.
Jun 02, 2010 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
My pm800-m2 computer does power up but no beep and signal although i have changed my psu and cpu.
check your RAM and your VGA card (if any). If the ram is not recognized by the motherboard, there is be no display at all. Also the VGA card.
So, remove the ram, clean the ram slot on your motherboard s there might be dust on it, check your VGA card if it is well fixed. Also check your VGA cord, is might be damaged, Check the pin on the cord to be sure its intact.
Do general troubleshooting your the motherboard and there should be a difference. But if there is not difference, then I think its high time you got another motherboard.
Lastly, test all the components of the motherboard with another motherboard in other to know precisely where the problem is coming from.
Be more patient with the motherboard and you will definitely get a solution.
Good luck.
May 26, 2010 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
PC2700 or PC3200 DDR memory in this mobo ?
MEMORY ecs_buttom_03.gif 2 x 184-pin DDR DIMM socket support up to 2 GB ecs_buttom_03.gif Support DDR400/333/266 DDR SDRAM
Copied above from ECS website so the answer would yes as it supports up to 3.2GB/s transfer rates at DDR400
May 14, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Time and date changes daily to january 3
there is CR 2032 or CR 2016 installed on the mother board open the cover of ur cpu and u can see that battery installed like coin simply change it and it will be fixed
pls let me know if i fixya problem
Feb 25, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Overclocking the cpu
eneble cpu overcloking from bios settings, but I do not recomand this cause you might fry it..:P so...reboot , press del to enter bios settings ..choose cpu setings by pressing enter , choose overcloking ...sellect by pressing enter ..at the end ya press F10 and yes to save and reboot
Jan 07, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
PM800-M2 Restarting
reformat means that you have to install an fresh copy of your operating system to the hard drive. if you do have a cd of your windows installer like windows xp, just put it in your cd drive and restart your computer and boot from that cd. be sure to erase the partition that has your corrupt operating system installed ok to replace it with the new xp that your going to install...
that wasn't to hard was it?
Apr 30, 2008 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Restarting PC
your motherboard may be experiencing compatibility issues with that memory youve jst installed. it will work for some time but when it starts to become unstable, it will restart, you have yo adjust the memory timings for that memory in BIOS.
Mar 18, 2008 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
VIA ECS PM800-M2 PM800 P4FSB 800 Supports Intel Pentium 4 Processor (REV:1.0) (ECSPM800M2V10) Motherboard Logo
75 people viewed this question
Top VIA Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Tony
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
