Question about Kirby G5 Bagged Upright Vacuum
Kirby Vaccum How do I put on the belt
Rotate the square knob on the front of the attachment to the "Belt On" position (green marker). Insert your fingers in the attachment port (the round opening on the back where the "hook" is) and position the belt so it's centered and as high up as it will go (that's usually just below the center of the opening. THEN rotate the square knob on the front to the "Belt Off" position. You should feel the belt tighten up and the know harder to rotate.
TJ
Posted on May 02, 2008
  • TJ May 02, 2008
    Whoops, I meant "knob" harder to rotate, not "know"
How to put on attachment hose
Here is a walkthrough on that with pictures:
Vacuuming Bare Floor with Kirby vacuum
You will need to take off the nozzle to attach the hose.
Install Kirby belt and nozzle
800-775-6586
GoodVac com
Dec 05, 2014 | Kirby Vacuums
How to put a belt on silver addition kirby vaccum cleaner
The following site has videos for changing belt on the Kirby vacuums. It should apply to your. Much simpler and better than just a written reply.
http://www.kirby.com/portals/0/videos.html
Sep 23, 2010 | Vacuums
How do i replace my belt on my kirby vaccum cleaner
Please see the following video we've shot on how to replace the belt on a Kirby Generation vacuum cleaner. This should explain to you step by step the procedure to replace the belt. If you need to purchase a belt, we can also help you with this.
Feel free to request a repair clarification if you have any questions I can answer.
If you found this repair helpful, please be sure to rate the repair by clicking the 4 Thumbs Up Icons in the top right hand corner of the repair. Thak you so much.
Chris Jones
GoVacuum
Mar 20, 2010 | Kirby G4 Bagged Upright Vacuum
Belt for heritage 2
remove power head turn knob on front counter clockwise look in hole on back of powerhead make sure belt is on the hook install powerhead back on motor turn knob clockwise
Jun 22, 2009 | Kirby Heritage II Vacuum
Kirby G5 rear wheels lock up completely when in "Drive"
When wheels lock when vacuum is OFF - it is normal. If it happens when Kirby is ON then there are a few things that may have gone wrong
Primary drive belt is broken or something is wrong with plastic gears. See how to check the primary drive belt HERE.
If it is fine and gears are spinning - then something must be wrong inside the transmission. Parts for tech drive are not available from manufacturer so you are on your own. It is not really complicated - 2 clutches that engage and disengage depending which direction you push the vacuum. But if something in there is broken - you have to get a new tranny. It is not like getting a transmission for a truck but it still will set you back by about 100 $.
Good Luck
Rocky
May 16, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby ultimate g
Vibrating – that usually happens on some short fiber or very dense carpets. When nozzle goes against the carpet fiber Kirby starts jumping. Try vacuuming the same place while facing opposite way.
Belt – red arrows means DISENGAGE. When you install the nozzle on the Kirby unit while green arrows match you will not be able to turn it on red. You must follow sequence (starting from nozzle off the Kirby, green arrows match, Kirby front lifter all the way up by pressing one of the pedals):
1. Turn Kirby knob to match red arrows. You will feel some tension and hook inside of the nozzle is supposed to catch the belt and stretch forming a loop for the Kirby shaft.
2. Put the nozzle on the Kirby and lock it on with the latch.
3. Twist the knob back to match the green arrows. YOU ARE DONE
Go to GoodVac.com Kirby vacuum online manual. There are some small details that you may want to pay attention to if you have removed the brush roll to install a new belt. Also there are some pictures that will help you understanding the process.
Sep 27, 2008 | Kirby Ultimate G Bagged Upright Vacuum
How do i put a belt on my kirby vaccum
here is a link to a site with step by step instructions for replacing a belt on any G series kirby...it also works for the new model.
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope this helps! :)
Feb 24, 2008 | Kirby Ultimate G Bagged Upright Vacuum
How to install kirby vaccum belts
Take the noozle off of the vac. take out the brush roll and old belt, put the belt over the brush roll and re-instal in the noozle. Turn the big square knob on the front os far as you can, it will lock in that position, then put it back on the vac and lock it down, then turn the knob the other way to release the belt unto the belt pulley.
Feb 20, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
79 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
