FixYa.com
Tags:
Nikon Coolpix 4600 Digital Camera
Nikon coolpix 4600.
posted by chrispost on Apr 29, 2008
Hi Mangoe
I have a nikon cool pix 4600, i put my phone SD card into it when the camera SD ran out of memory. it came up with "system error 10," and will not work again. I have even tried putting the camera SD card back in and it comes up the same. Can I fix it??
regards chris
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 11, 2008
Not Rated (0)
mangoeater2
Rank:Guru Guru
Rating: 86%, 92 votes
Hi I found this info on the Nikon Australia website:
"System Error" or "Lens Error" message in LCD monitor Question My COOLPIX camera displays a "System Error" or "Lens Error" message. What should I do? Answer Having a "System Error" or "Lens Error" message displayed on the camera's LCD monitor would generally indicate that your camera needs servicing. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. To troubleshoot, please try the following:
  1. Use the memory card that originally came with your camera (or a Nikon approved card).
  2. Remove and replace the battery.
On the other hand, a Lens Error generally means that an error has occured during the lens operation. To troubleshoot, please try the following:
  1. Turn off the camera.
  3. Turn on the camera.
If the above tips do not help, your camera must be sent to our Nikon Authorised Service Centres, there are no user serviceable parts in our Nikon COOLPIX cameras. We apologize for any inconvenience caused and we will do everything to repair your Nikon camera as quickly as possible. Click Here for our Nikon Authorised Service Centres details.
Seems you may just have to remove and replace the battery - sort of like a Windows Restart to fix a computer problem! - this would reset your camera's memory.
Hope this helps.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Digital Cameras problems?
date and time printed on pics
I have a Fuji FinePix F470 (it... Answer This...
Kodak high performance memory...
I have taken a bunch of... Answer This...
Terribly short battery life all...
Ive mostly used those green and... Answer This...
Nikon e4600 wont download...
When I try to download pictures... Answer This...
Downloading pictures from Nikon...
Repair Service
Find Digital Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
