Question about GE 25932 Cordless Phone
Phone prompts when i try to call my back or other business and i have to use phone prompts they do not work
  • leesonthebea Apr 29, 2008
    asap please my child is trying to use this phone for home school it is being used with voice over internet
I had the same problem, I wasn`t able to follow the prompts.
I found the problem to be the tone was set on pulse.
With the phone off press the menu/mute button till 1Tone 2Pulse appears on the screen. Select Tone and then menu/mute to save.
Good luck
Posted on Apr 30, 2008
Activating serial number on galaxy s3 T-Mobile
Right odin doesnt work apparently i dont have a pit partition? Whatever that is? So i have gone back top basics...... i have managed to get samsung kies to recognize my phone by using a upgrade and initialize function (this prompted me to upgrade samsung kies). It asks for you model number and serial number and downloads the latest firmware.
I believe is a positive step as at least the PC/Laptop is now recognising the phone in some way and its using the approved (by samsung) method of restoring.
This should take approx 1hr to do so.
I will report back with the findings..Thanks
Aug 20, 2013 | Computers & Internet
I have the samsung IDCS 28D, how do I change the voice mail to a temporary holiday greeting?
Hi, all you need to do is to go into your voice mail via the voice mail key, once in listen to the prompts until it says ' to assign your no answer greeting'. The prompts give the option to listen and record a greeting, however make sure that you delete the original and record a new greeting other wise the messages play back-to-back! I've posted a video to help you to do this, or visit www.abbeytelecom.com for further advise
Dec 21, 2010 | Samsung DCS 12 Corded Phone
How do i foward to my cell phone from Nortell T 7208 and remove feature
most phones use *72 ### ### #### and *73 to disable it.try *72 first listen for prompts, if no prompts and only a dial tone, then *72 followed by the number to forward to. Hope that helps you
Aug 29, 2010 | Nortel Business Series Terminal T7208 -...
Like the others who have posted on here, I too
Try this:
Press "Feature (star) (star) T I M E"
and follow the display prompts.
Good Luck!
May 09, 2010 | NorStar M7310 Corded Phone
My phone says jum error 513 rest
Your operating system on your phone has been wiped clean off it I believe so what you need to do is download the lastest OS to your computer and then hook your phone to the computer and run desktop manager and then it should prompt you to install the operating system and then you should be back in business unfortunatly you lost all your contacts and any other information on your phone but it should now work again.
Cheers,
Kyle
Jul 03, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Norstar Flash
phone is not programmed for forward busy no answer.
Feb 06, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Nov 28, 2008 | Panasonic KX-T7730 Corded Phone
SGH-C417
if u can just try opening ur set clean it and put ur sim back it should work may be ur not in service provider range. try selecting some other network.
Jun 14, 2008 | Samsung C417 Cellular Phone
Network busy
itsc hance if ud ask me coz..."network busy" message appears only when there is a problem with your network..there is nothing wrong with ur phone..it wud work perfectly fine..try inserting the sim card and refreshing it..if this problem prolongs..ten try caling ur network provider...coz they r the problem and not ur phone..All the best
Happy to help
Have a nice day!
tc
Jun 09, 2008 | Motorola Mobility RAZR V3
GE 25932 Cordless Phone Logo
41 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
