Question about HP Computers & Internet
2 problems - 1. Window shows unable to start driver for hpoipm07 (exe) 2. Black print is blue. Have put in new cartridge and cleaned printheads. Please help. Thank you, Lisa Pfau lisajoep@hal-pc.org or 713-822-4114
SOURCE: HP 3310 - problem with black ink supply
I heard you can get the 3310 to do a pump up the tubes cycle but i don't know how to make it do it. Pressing the ok and cancel buttons when you power up didn't work for my machine. Which has too died a inkless black death!
Posted on Oct 01, 2008
SOURCE: k550 air in ink feedlines
I have had this happen a couple of times and have cured it easily. It has only happened with the black with me. It seems to be caused by air in the ink feed line. With the printer switched on open the top cover and hold the resume button for 5 seconds. The printheads should move to the left and you may be able to see air in the pipe(s). Remove the printhead of the offending colour(s) then insert a syringe with the plunger fully down into the rubber that the printhead connects to. Draw up the syringe plunger to draw ink/air through until you can see no more air in the pipe. Replace the printhead and close the cover. The printer should now do a calibration with the offending colour hopefully now working.
Posted on Mar 29, 2009
  • 3 Answers
SOURCE: I have 2 Epson R230. One has a bad printhead, in
Befory you toss the printer, try this!
Take a syringe, 1" piece of rubber tubbing that will fit over the head input snugly, (auto parts house stocks some that works fine). Fill the syringe with a good head cleaner, slightly warm it in the microwave (try 5 seconds to start). Attach to nozzle, gently pull back just a bit, then apply a little pressure. If it accepts the fluid, STOP, You can clean the syringe, add the proper color ink, inject just a small amount. reinstall a known good cartridge, clean heads couple times checking results, if ANY streaks or color appears, clean again! Sometimes letting it sit overnight allows the head to fill with ink. I have had very good luck with this method, also some will not clean properly, just depends on how bad it is clogged.
Good luck..
Posted on Sep 21, 2009
SOURCE: Black ink started to print blue/mauve
Many thanks for the suggestions received. Have been told by HP to
change the black printhead - which has solved the problem!
Posted on Dec 23, 2009
leitusdotcom
  • 172 Answers
SOURCE: when turning on Sb-4100 I get message
Hi rbrown454. That file is for your HP printer. Go to hp.com and click on support and drivers and download the latest driver for your printer. While it's downloading go to add/remove programs in Control Panel and uninstall ALL HP software. Do not restart, wait for the software to finish downloading and restart. Then reinstall the software you downloaded from the internet.
In case you have the CD, reinstall the CD but make sure you uninstall ALL HP Software.
I hope this helps. Please do not forget to rate and provide positive feedback for our fast/free support today. Thank you :D
Posted on May 10, 2010
Hp 8500A won't print if one ink cartridge needs to be replaced
Its simply because the cartridge is not making a good contact with its socket.
1-switch off the printer and totally unplug it 2-clean the cartridge properly
3- check the cartridge clip
4-return cartridge and send a feedback to us
Jul 09, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
The black ink has stopped printing. Put in two different new cartridges and that doesn't seem to be the problem. It was first noticed when photos were printing out funny even after changing the color...
Make sure you are inserting genuine Lexmark cartridges.
Try to clean the cartridge nozzles. Refer to the steps below:
Cleaning the Print Cartridge Nozzles:
1. Open the Lexmark Solution Center. Click Start > Programs or All Programs > Lexmark 1300 Series. Select Solution Center.
2. From the Maintenance tab, click Clean to fix horizontal streaks.
3. Click Print. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
4. Print the document again to verify that print quality has improved.
Using the control panel
1. Press Menu.
2. Press the down arrow button until you highlight Clean Cartridge.
3. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
Oct 13, 2011 | Lexmark P4350 All-In-One InkJet Printer
I changed the printer cartridges in a hp officejet 4315 and now it won't print-flashing error meesage "Cartridge Error:refer to device documentation to trouble shoot" What do I do? i
Good Day Sir, hope this will help you.
print cartridge troubleshooting for hp officejet 4315 :
1. Remove the black print cartridge from the slot on the right. Do not touch the ink nozzles or the copper-colored contacts. check for possible damage to the copper-colored contacts or ink nozzles.
2. Reinsert the print cartridge by sliding it forward into the slot. Then push the print cartridge forward until it clicks into the socket.
3. Repeat steps 1 and 2 for the tri-color print cartridge on the left side.
4. If the problem persists, print a self-test report to determine if there is a problem with the print cartridges.
5. If the self test report shows a problem, clean the print cartridges.
6. If the problem persists, clean the copper-colored contacts of the print cartridges.
7. If you are still experiencing problems with printing, determine which print cartridge is experiencing the problem and replace it.
have a nice day.
7.
Jun 22, 2010 | HP Officejet 4315 All-in-One Printer
I put blue ink in a black cartridge and from then
Hi, you shouldn't have done that, because the color cartridge and black cartridge are not of the same make, what you need to do now is to change the cartridge, get a new cartridge to replace to troubleshoot,let see if it will print.
Compliments and wish you best of luck.
Jan 02, 2010 | Canon PIXMA iP1600 Printer
I put a new ink cartrige and printer prints low coulour tone.
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.  2. Select "Clean and Fix Horizontal streaks."  Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.  2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.  3. Get a damp paper towel.  4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.  5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.  6. Next dab the cartridge on the towel to make sure that the ink is flowing.  7. Snap the cartridges back into the printer.  8. On your computer, select "Old Cartridge install."  9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 26, 2009 | Lexmark Color JetPrinter 5700 InkJet
HP 6310 printer says HP 95 tricolor is empty.
Ray,
It sounds like you need to replace the cartridge with a new one. The electronics may have went out. We see this usually during the winter months when the static electricity in the air is high and we shock the cartridge. I would also NOT recommend cleaning the head/jets of the cartridge with alcohol. The electronics are fine to clean with alcohol both inside the printer and on the c artridge, but the head will dry out. We recommend taking a damp warm wet paper towel, placing it on a protected surface, and placing the head of the cartridge on the paper towel until you see some ink appear. Then put it back in your printer and let the printer clean off the bottom. If the printer is not cleaning off the bottom of the cartridge, the printer cartridge wiper on the carriage may be broken or stuck.
May 16, 2009 | HP Genuine HP 95 Tri-color Inkjet Print...
Despite installing new cartridges,cleaning and priming, my HP Deskjet 710C prints pink only. Using Windows XP test page shows no blue, or yellow.
hi,
do you installing both cartridges (black and colour)?
if you do so, my advice is to reinstall the driver for your printer.
if you install ONLY the black cartridge, and the color cartridge remain the old one, (which in my opinion is the present case), your problem is from the color cartridge.
The color cartridge have 3 colors and this are: cyan (some kind of blue), yellow and magenta (similar with a pink color, but more intense). The problem is simple: in your color cartridge has left only the magenta color, cyan and yellow tanks are empty.
have 2 options:
1. buy a new color cartridge
2. refill the color cartridge.
Sep 23, 2008 | HP Office Equipment & Supplies
Problem with Canon MP730
hi, i was having the exact same problem with my printer. and i also tried reinstalling the driver. after reading your post i decided to see if the printing problem occurred when i used the other colors, and it looks like it's only a problem with the black ink. i printed out a sheet with the text in red and another in blue and they came out perfectly. but the black grid that surrounded the blue text, still looked problematic.
so... that means that the black ink is the problem. i haven't tried putting in a new cartridge. did you say that your problem occurred after you put in a new black cartridge, or did you try putting in a new black cartridge and you still had the same problem?
May 06, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
New Ink cartridges registering as empty ...
Is it an HP printer? We had the same problem at work with print cartridges purchased at Staples. They have a major quality control problem. Your new print cartridge may be empty or dried out (died on the shelf). It's my problem at work, as I have over 80 HP deskjets, and Purchasing still insists on buying the Staples cartridges rather than the HP.
Sometimes if you shake a print cartridge really hard it may correct the problem. However, I would buy or borrow a black HP print cartridge and try it out in your printer. Works almost every time on the job. Good luck.
Apr 17, 2008 | Computers & Internet
how old is this one? And sometimes, those 'replacement' cartridges are anything but standard.
recycle your printer responsibly
Mar 16, 2008 | HP Photosmart C4180 All-In-One InkJet...
Computers & Internet Logo
133 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
