Question about Compaq Presario 700 470024-192 Notebook
Internet Explorer Closes
When I close a website all other website pages will close. And I will get an error message that windows explorer has encountered a problem and will need to restart. This is a new laptop. Problem has been occurring since the laptop was purchased.
  • Compaq Master
  • 5,568 Answers
If your system wasn't set up to do MS Auto-update from the factory, I recommend you use it.
It is likely that the IE and possibly other Windows functions need one of the hundreds of tweaks MS constantly makes to try to keep their Edsel working properly.
Open your Control Panel from the misnamed 'Start' menu, click on Automatic Updates and check (or set) your settings.
BTW, lots of luck with your Compaq/HP laptop; I won't own another one nor service any HP system again.
Posted on Apr 29, 2008
I need a fix for internet exployer
Microsoft's Internet Explorer 8 (IE8) browser includes "add-on" applications that can be downloaded and installed from Microsoft, or third-party providers, into Internet Explorer.
Occasionally, add-ons may conflict with other add-ons or software on the computer, causing errors.
These can also occur when IE settings conflict with newly installed add-ons.
Resolve add-on related error conditions quickly in IE8 by resetting Internet Explorer to Microsoft defaults.
Click the "Start" button. Click "Run" or "Search," and type "inetcpl.cpl in the "Run" or "Search" box, and press the "Enter" key.
Select the "Advanced" tab in the "Internet Options" window, then click the "Reset" button.
Click the "Reset" button again to confirm that you wish to reset Internet Explorer to Microsoft defaults.
Select the "Close" button, once the display indicates that the reset process has been completed.
Click the red "X" in the upper-right corner of Internet Explorer to close the browser.
Open Internet Explorer and the errors should be resolved.
also
Experience problems with Internet Explorer 7 right off the bat, and it may be due to installation problems.
Make sure you reboot twice after installing the new browser.
Download any updates for IE7.
Check the Microsoft website for recommended updates if you don't have automatic updates turned on for your computer.
Check your add-ons, those "extras" like ActiveX controls for your browser, if you still experience problems.
After accessing "manage add-ons" through the "Tools" menu in your browser window, disable all add-ons, and try browsing.
If you can successfully browse without errors on the page, then one of your add-ons may be the culprit. Enable add-ons one at a time and try browsing.
Once you find the problem, delete it or update the add-on to work with Internet Explorer 7.
Contact Microsoft if a website denies permission for entering when it shouldn't.
It could be a problem with document. domain property or the protocols of the URLs not matching.
Update and run the most recent version of JavaScript. JavaScript is a scripting language used on many websites.
Adjust security settings in the browser if you still experience page error messages.
Select the "Tools" menu and access "Internet Options." Under the "Security" tab, choose "Custom Level" to pull up the security settings window and review for possible problems.
Hope this helps
Nov 13, 2012 | Microsoft Internet Explorer 8
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; FBSMTWB; GTB7.0; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729;...
Your computer is using Version 8 of Internet Explorer, under Windows XP, with the 'ASK.COM' toolbar installed into Internet Explorer.
You tried to access a web-page containing some 'js' ("JavaScript") code, but there was an error-condition that arose while interpreting the JS code.
Delete all "Temporary Internet Files".
Close Internet Explorer.
Open Internet Explorer.
Try to access the same web-page that gave you the error-message.
Try accessing that web-page on some other computer, to see if _more_ than one computer has a problem with that web-page.
Jun 20, 2011 | Facebook Computers & Internet
WHEN I OPEN IE THAN THE MESSAGE APPEARS AS WEBSITE RESTORE ERROR.AND I CANNOT SURF THE WEBSITE AND AFTER SOMETIME IT CLOSES SUDDENLY.SO PLEASE CAN U HELP ME TO RESOLVE THE PROBLEM
try the following steps , close Internet Explorer.
if you are using WINDOWS XP
click start>run, type in inetcpl.cpl , press enter
if you are using windows vista / windows 7
click start> in "search programs and files" type in inetcpl.cpl press enter
internet explorer properties will open up. go to the last tab which is Advanced.
Click on RESET
proceed with the reset and try again
Sep 12, 2010 | Microsoft Internet Explorer 8
Sometimes when I click on the Internet Explorer icon, and error message appears in front of a blank web page. The error message says "Internet Explorer has stopped working. Click to close program". When...
Try a scan with your virus scan, then with a malware scanner, i use Malwarebytes.
I would then use CCleaner, use the registry cleaner also.
This will clean out all your temp files, and remove any registry errors that may be causing IE from starting properly.
You could also use Firefox, or chrome as your browser if this does not fix it
Sep 05, 2010 | Microsoft Internet Explorer 8
Internet exploer closes after I sign in to Yahoo on windows vista
Yes, you are infected. Go to safernetworking.org and download spybot search and destroy the current version.
Go through the thing carefully. If you need a detailed explanation on how to configure it to clean out the system, because it will need to be configured properly, then it can get out the infection.
If it can't, there is another way, but this is the easy way.
Aug 09, 2009 | Microsoft Windows? Vista Home Basic...
Everytime I go to BEBO page I get a Internet Explorer error and it closes internet down only on this site HELP !!! Internet Explorer has encountered an error then closes down
goto
www.firefox.com
download free broswer, and install, do not import your Explorer settings
goto www.java.com
install the free java program
goto www.macromedia.com (it will take you to an adobe page, since they bought the company) on the lower right hand side of this page there is a link to download the free flash player.
close the browser. run the install firefox program, if you have not. run the flash install program, and the java install program if you have not. be sure to follow my order.
restart you computer
now you can goto to BEBO with firefox
never use Explorer again.
Jun 28, 2009 | Computers & Internet
Internet Explorer stops working
Greetings my name is Mark and I will be glad to assist you.
When you close out does it give you a message to "close all tabs. If so and you ok it will shut down everything that internet explorer is working on. When I/E is open and you want to close only the screen you are on look at the top of the page and you will see the tabs that are currently open and close them individually from there.
I hope this helps.
Let me know ,Be mucho blessed,
Mark
Jul 01, 2008 | Compaq Presario 700 470024-192 Notebook
Internet Explorer
i think your operating system is windowsxp. i find that sp3 have lots of bugs(errors) so better use your previous sp2. i think you need to perform fresh installation operating system. this might help you out about that IE problem.
Jun 19, 2008 | Insignia D400a PC Desktop
Pocket e800, Internet Explorer problem
The presumption that your Wifi Compact Flash Card work with Windows Mobile 2003 is higher than working with Windows Mobile 2002. The new Windows is supporting much more hardware than the old one.
Sep 08, 2005 | Toshiba e800 Pocket PC
Compaq Presario 700 470024-192 Notebook Logo
55 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
