Question about Microsoft Xbox 360 Console
Xbox 360 when i turn on my conole and put the input on 3 as i usualy do, the screen stays blue
  • 21 Answers
Make sure the setting is right on the cord. Where it plugs into the xbox you can have it on normal or HD, make sure you are using the proper setting. If that doesn't fix it try getting a new set of cables.
Posted on May 01, 2008
My dynex tv only shows channel not available message?
Okay- the three cables (red, white, and yellow) are called RCA plug connectors. They are commonly used to carry audio and video signals.
Plug them into your Xbox according to the color codes- red cable connector to the red socket (jacks); then white to white, and yellow to yellow.
Now connect these leads to the RCA input jacks in the back of your t.v. - maintaining the same color code connections (red to red; white to white, and yellow to yellow)
The RCA input jacks on your t.v. should be labeled with an input number, to distinguish itself from the other inputs, like HDMI, S-Video, and such.
After plugging in your Xbox to the wall outlet or surge strip, turn it on.
Turn your t.v. set on.
With the remote control that came with your t.v. set, open the menu bar, scroll to... and open the "External Output" menu.
You should see a list of [however many] inputs your particular t.v has. Scroll to the input number that the 3 RCA cables are attached to, and press that number as the default video screen.
Exit the prompts and your Xbox video screen should be displayed.
Nov 27, 2013 | Dynex DX-LCD32-09 LCD TV
How do you get your xbox 360 to play, on a 65'' mitubishi projection tv,its connected but nothing comes on screen when i put a movie in just a blank screen and no sound,if i'm on a channel,the channel...
Hello
The Xbox 360 connects to a TV using either
- COMPONENT (red blue green for video, red and white for audio
- COMPOSITE (yellow for video, red and white for audio)
- HDMI
So, if your TV is on a "Channel", it is not on the correct input to view the Xbox 360.
Check the Xbox and verify which cables it is using to connect to the TV. When you find this, follow the cable to the back of the TV and find the input selection. It should be listed as the type and a number (i.e. HDMI 2, COMPONENT 1).
Have the Xbox on. Use the TV remote and use either the INPUT or the MENU options to change the input to the input that matches the port that the Xbox is connected to.
This should make the Xbox work.
When you are done with the Xbox, use the INPUT or MENU to change back to the tuner to watch TV.
Nov 03, 2013 | Mitsubishi WD-73734 73" Television
I have a Mitsubishi WD-73737 and when I turn on the tv the power light flashes very fast for a minute then stays a steady green and the screen is a solid blue. There is no sound as well. I have tried the...
Do you have the input turned on that you use the xbox for? Try different inputs as well. If you are getting the menu to come up, the blue screen is telling you that you don't have a signal being run through that particular input.
Mar 21, 2013 | Televison & Video
My xbox turns i hear the log in sounds but it stays blank.
try a different input on your TV or replace the AV cables
Aug 01, 2009 | Microsoft Xbox 360 Console
Xbox 360 Not Reading Disks
idk bout the blue screen. but my console would say the same thing bout put in 360 to play and it wuz cuz the disk was dug in a lil bit so it wouldnt read.
Dec 31, 2008 | Microsoft Xbox 360 Console
Audio works,but video does not
you need to put your yellow input cord in your output on the TV or VCR.
Jun 06, 2008 | Microsoft Xbox 360 Console
Xbox 360 has no video or sound on startup
I've fixed that problem several times now with a great xbox 360 repair guide
Mar 05, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
20 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
