Question about Samsung (SP0822N) 80 GB Hard Drive
Problem in Harddisk
My 80 GB Samsung Make HDD is not detected, if conected as a master. If conected as a slave with another Hdd, it is detected but no logical drive is read from it. I could not access data in it. Please give me solution.
  • 95 Answers
Does it make any sounds like any of these?
Does it spin up at all?
Posted on Nov 08, 2008
How to set master, slave settings in sata hdd
In first HDD put the jumper in first vertical pair of pins from power socket side, it will become master and second HDD put jumper in second vertical pair of pins from power socket side it will become slave.
Regards
Ashly
Feb 02, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Jumper settings for a maxtor N256 master with slave
Select the maxtor HDD as master by setting the Jumper to the extreme left of the hdd; i.e. next to the data cable.
Remove all jumpers from the other HDD which you want to put as slave.
Sep 02, 2009 | Maxtor DiamondMax 80 (96147H6) 61.4 GB...
I have a seagate barracuda 7200 7 40GB, with 2 partitions: 1-(c:/)WindowsXP, 2-(d:/)for save my personal files.At PC startup, the message that appears is missing OS. BIOS detected HDD, but Windows CD no,...
you can take backup of D drive om other computer .
Conect your harddrive to that other computers CPU but make sure that your hardddisk is slave which has issue you can set slave your hdd with jumper read on harddisk.
then connect it to cpu with SATA or IDE .
Then winxp find that all partition then take backup.
AND IFyou haven't other computer you need winxp bootable disk.
Boot your computer with winxp disk then follow the procedurer then you see on screen
your old winxp for repair then when it ask for "r"
Presss "R"
thats it.
Thwen it repair your winxp then you can use easily.
Aug 22, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
I have Intel 810e PIII 1 GHz 512 Mb Ram 20 GB HDD. OS Win ME I want to add secondary HDD. Which one should I preferr 80GB / 120GB / 160GB. and will install new OS say Win XP or linux in Secondary Hdd....
160gb - but ensure the bios is up to date and check the motherboard manual as that will or should explain about maximum capacity of hard drives but am sure it should be fine.
If it is not and does not detect all of it you can partition the partitions into smaller amounts ie 80 gb partitions each ?
May 19, 2009 | ASUS Intel 810E Chipset CUWE-RM...
SATA HDD make SLAVE
IDE Cable with 3 connectors (you have 1 or need to buy 1) :
- blue: conn to motherboard
- black: conn to master HD
- grey: conn to slave HD
Cable (select:) cable will auto detect with most modern HD's from same type (SATA it was i think) and you need to go to you're BIOS, set up cable select for the HD's. Maybe best to set up master first, not both at same time. If you have a SATA and ATA set up the master first, then other. So if SATA is slafe but it in grey connector, otherwise black. For an ATA you might need a converter cable for the power, most motherboards don't have 1.
Oct 25, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
MATSONIC MS8157E MAINBOARD
Check the jumpers on the drive, should either be master/slave or all cable select.
Aug 12, 2008 | Matsonic MS8147C+ (N82E16813184008)...
Samsung 80 gb Hard Disk Un allocated
All ways best to used new cables (sata/Ide) I like to set jumpers on the HD's never cable select. Also try installing one harddrive at a time. Second make sure in bios is set to boot from main HD.
May 12, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
SP0812N HDD 80Gb
this mainly depends on The Operating system, if your using Windows 2000 or above it should,nt be an issue.
sometimes there are limitations on 2 hard-drives sharing the same IDE channel on the mainboard.
Try putting the second hard-drive on the secondary motherboard slot, with it,s own individual cable.
If non of the above works, it,s possibly not formatting correctly.
you,ll need a program that zeros then formats the drive.
Hope this helps.
Mike @ Compurepair.
Feb 22, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Regarding toWorkstation HP xw6400
keep the first harddisk as master and second harddisk as slave ok
Oct 04, 2007 | Computers & Internet
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Samsung (SP0822N) 80 GB Hard Drive Logo
207 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
