Question about Philips Magnavox 9P6034C 60" Rear Projection Television
How to get to the crt's to clean?
I have a phillips 43 in how do you get to the crt's?
    Genius:
  • 1,139 Answers
Hello fixitmama33,
Be very careful these CRTs contain a hazardous coolant material in the cooling jacket and should only be handled by a professional TV repair person. First, if you are intent on doing this. I would suggest you get a schematic and study the exploded view of the TV and then follow the instructions on how to get to the CRTs properly.  I say this because there are a few things you have to do before removing the CRTs first you have to discharge the stored voltage in the CRTs (around 2Kv-15Kv) "Yes I have seen a CRT store up to 15K volts", This should only be attempted by someone who knows what to expect.
I hope this helps
Thank you,
Shuttle83
Posted on Apr 29, 2008
How hard is it to change the cooling fluid in phillips projection tv.
The CRT coolant change is all mechanical which involves removing the crt and disassembling the coolant chamber so it can be cleaned then reassembled and filled with coolant the phillips CRT coolant kit from www.tvrepairworld.com has the coolant and the instructions for the repair on cd
Jul 31, 2011 | Philips 60PP9352 60" Rear Projection...
How can I improve the picture quality, its all discolored...the settings are not doing much to help, I cleaned to screen with a mild soap solution with a sponge and I cleaned the lenses well... What is...
The CRT coolant needs replacement. Phillips has a bad problem with CRT coolant needing replacement. You can get the Phillips CRT coolant kit which contains the coolant and the CD with instructions from www.tvrepairworld.com
Dec 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
Phillips 43" T.V sound is fine Picture is Faded? Still visible but very light and faded..How do I fix
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 06, 2009 | Philips 43PP9202 43" Rear Projection...
Night seens are very dark
Call a good TV Tech and have him check all crt anodes for proper connection. Also remove & reinstall all crt boards, clean spark gaps. This TV is also known for having bad convergence amp IC's.
Jul 29, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Yello colour and fuzzy
the coolant will most likely need replacement. Heres alink to the repair kit which contains the coolant and detailed instructions on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
Jun 23, 2009 | Philips 43PP9202 43" Rear Projection...
Phillips 50p8341a
Replace the coolant in the CRts thats a common problem with Phillips and magnavox rear projections. Heres a link to the coolant replacement kit for your model. The kit contains the replacement coolant and step by step instructions with pictures.
Jun 12, 2009 | Philips 50P8341 50" Rear Projection...
2005 phillips crt 27 inch tv
need electrolytic capacitor replaced in vertical circuit
May 07, 2008 | Televison & Video
Picture is getting dimmer
Yes! CRT's do go weak with age and use. It is very possible that the CRT's are the problem.
The service tech can take voltage readings of the power supply, and biases to the CRT's to know if they are actualy weak.
From your description, I would thing very strongly that the CRT's are the problem.
Jerry G.
Apr 23, 2008 | Toshiba 43H70 43" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
27 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
