Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer spin cycle
Motor sounds like its working but washer will hardly spin or not at all
    Genius:
  • 1,073 Answers
Check te direct drive coupling in between the motor and the transmission if it is broken replace it
Posted on May 01, 2008
My washer wont rinse. It seems to have a hard time spinning, any suggestions?
do you hear the motor running ,it will drain but no spin,this has no belt in it it's built just like a whirlpool washer because whirlpool owns maytag now and this washer has a motor coupling,i would check this first,do you know if the agitator is working or do you hear a grinding noise when it's running?watch this video and you don't have to disconnect the wire harness to the motor if you don't want to,i don't just put motor off to right side still connected
http://www.youtube.com/watch?v=9K1KHEogf3c
Apr 09, 2013 | Maytag Centennial MTW5800TW Top Load...
Kenmore washer goes thru all the cycles at the two spin cycles it will pump the water out but it won.t go into the cycle if you grab ahold of the drum and manually give it a start ...
pull the washer out a little awy from the wall,tilt it back so the top rests on the wall,feel around behind the motor,it sounds like the tranny is going and you might find oil around near the back of the motor where the coupling is,also check the coupling,it's behind the motor,it hits the tranny to and when the motor spins it spins the tranny,i've seen the middle of the coupling wear out just catching and if you help it out it will spin but it sounds like the transmission is bad,it's not hard to change it out.send the model number,i can look up your machine,tell you how much a new tranny is and tell you how to change it out,or replace the washer if it's old and put the money into a new washer
Nov 05, 2010 | Washing Machines
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Washer won't spin, but making funny noise and water drains
You have a broke motor coupling broken between the motor and transmission the part is not expencive but a little hard to explain how to put it in.
Mar 29, 2009 | Whirlpool Washing Machines
Washer won't spin
Check the washer motor. Make sure that the motor is getting correct voltage and is working and spinning when you turn it on. It sounds like the motor is bad. You can remove the back cover to get to the motor to check it out
Feb 13, 2009 | GE Spacemaker Washer and Dryer Electric...
Agitater does not spin
the transmission needs to be replaced
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Spin cycle problem
hi this is the part you need to replace motor drive coupling located on the motor and the transmission. replace this part $25.oo thanks the appliance doc
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore portable compact topload washer model 110 49722992--won't spin!!
sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753a . mounts directly to the motor shaft and connects to the transmission, order a new one it installs between the motor and transmission,assy
Apr 03, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
GE Washer WPSQ4160T
TRY REMOVING FRONT OF WASHER YOU WILL SEE 4 SHOCK LIKE PISTONS TAY GET DRY AND MAKE GRINDING NOISE OR SQUEEKS LUBERCATE ALL REAR HARD TO GET AT MAKE SURE YOU GET TOP AND BOTTOM (RAY)
Dec 07, 2006 | GE WBSE2090A Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal De
