Question about Motorola Mobility RAZR V3
Can I Have my razr repaired
I have 2 razr phones . one was dropped in the toilet and ahs not worked since. Picked up very quickly and dryed off and applied heat from blow dryer to dry internal parts. No luck
# 2 I was told by verizon because the was a pink dot near the battery pack that I allowed the phone to get wet. Not true. In any case neither one works. Any suggestions
    Brigadier General:
  • 7,752 Answers
Then you should take the phone to a repair center and have it fix for a fee.
The white dot on the back of the phone is to safeguard the manufacturer from malicious damaged or use by the customer.
So if it is red that means if had to come into contact with liquid , moisture or water at sometime.
Posted on Jun 29, 2008
My LG cell phone was dropping into the toilet bowl, I picked it up and all got back to normal after I dried it up. However, the '0" button was not working and no response. Can someone help me?
It is likely an electrical short. You can try burying your phone in a bag of rice (dry, of course) to **** out any more moisture. I've also heard of people putting their phones in the freezer though I have not tried this myself
If this doesn't work there's not much you can do besides taking it in to the dealer. Say it was rained on or the button quit working by itself.. not that you dropped it in a toilet.. and you're likely to get off cheaper or even free
May 04, 2011 | LG Cell Phones
My phone screen went blank after dropping in the toilet
You should have left it dry instead of turning it on, you probably have corrosion now, find a local place that works on phones to see if they'd work on it.
If you want to try to completely dry it, put it in rice for 24 hours minimum to draw out all moisture.
Aug 03, 2017 | Motorola Mobility RAZR V3
I dropped my cell phone in the water
http://www.fixya.com/support/r3771170-phone_water_damage
Oct 08, 2009 | Motorola Mobility RAZR V3
My phone fell in the toliet
Switch off the phone as soon as possible. Allow it to dry else the circuits will be affected. Check if it works tomorrow, if it doesn't you might need professional help. Some components will require change.
Jun 03, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Dropped phone in toilet. please please please help. i need my ph.
Apr 24, 2009 | Motorola Mobility RAZR V3
Keypad remains lit even when turned off
you need to take the phone to a mobile repair shop and have them service it for you.
Nov 13, 2008 | Motorola Mobility RAZR V3
RAZR - Sploosh!
the main flex cable connector in the screen is most likely corruded... u need to open the cover and get it cleaned and replace it.this might be a bit difficult if u don't have a t6 or a t4 screwdriver, but if u do u need to remove the 4 screws located under the rubber stubs on the inner screen. pry off the cover and pop off the main connectore on the left hand top of the screen and clean it carefully with an old tooth brush and a little spirit. u need spirit because it evaporates quickly. you don't need anymore water in your phone.
If this doesn't work u need to get someone with another razr and go through the steps of copying your numbers onto your simcard. Each step u take on the working razr make sure u do the same on the damaged one.remember u can't see the screen on the damaged razr.when u are through u could always remove your sim card and try locating the numbers in another phone to see if u were successful.when you are doing the copy transfer on your phone if it was a lot of numbers make sure u give it at least 5 minutes to complete....try this:-
center button
left arrow
up arrow
center button
menu button (button above the four way toggle)
down button 10 times
center button
down button
center button
wait for five minutes...
try your simcard in another phone and confirm your numbers...
this should work.
sam !
May 10, 2008 | Motorola Mobility RAZR V3
Dropped fone in toilet
Hi, You can purchase a spray called electric cleaner that cleans small electric components and dries very quickly. But you will have to open the phone and spray on the small circuit board inside. If it still doesn't come up after that then it might possibly be dead. Sorry and good luck Lolita
Jun 09, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
64 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
