Question about Philips 43PP9202 43" Rear Projection Television
Tv comes on and shutts off immediately
I had a tv repair guy come buy and look at my set and I told him what was happening. My blue was out of wack and like every other day the tv comes on and shutts right back off. Today he took out the STK392-120 ic's. So then he still tries to turn the set on. Will they work without the ic's? If so what wrong with my tv?
  • frenchy64 Jul 19, 2008
    i have just replaced the converg ic`s and now all the tv does is shut off
    i have checked for bridges and dry solder , the only time i see a picture is just before it goes off . can you please help .
    frenchy64
    Problem Solver:
I pulled the yolks and the tv still wont give a picture , the only time you see a picture is when it is turned off or stand by for a split second i also have no sound and no video from the dvd payer , befor replacing the converg i had picture and audio and i also had sound from the dvd but no picture can you please help .
Cheers
Frenchy64
Posted on Jul 19, 2008
  • Philips Master
  • 8,617 Answers
He was checking to see if the set stayed on with the ICs out if it did the ICs are shorted. Its easier to unplug the convergence yokes and try it but some techs do it differently
Posted on May 07, 2008
2 Suggested Answers
  • 293 Answers
SOURCE: Tv comes on and shutts off immediately
Well no, it won't exactly work with out the ICS which is an internal control relay card. He most likely was thinking it was a power distribution problem. My suggestion is to look at the power supply and make sure nothing is bridging any of the circuitry. Just like a computer the on and off button is attached to a set of pins, and just like computer motherboards the controls also exist for a reset. And if anything bridges these pins turning on the unit will just cause it to shut down again. Also look for water damage and heating damage that might have caused problems with the power supply unit.
Posted on Sep 12, 2008
My television just went off! We tried to turn it back on but it wouldnn't come back oh. Finally the button flashed red like it was trying to come on and we heard 2 or 3 words then that was it.then the...
Tries tv unplug,replug it back like about an hour later.By letting the tv restting itself back to the factory setting.Now tv should be working again.If it have the same result.Yes,the power supply board is the problems and the causes.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Feb 03, 2011 | Hitachi P50H401 50 in. Plasma HDTV
Blue light blinks three times then pause...blinks 3 times then pause etc etc.. no audion or picture, just black screen with the blue power light flashing like mentioned
My Hitachi 50" plasma has exactly same problem. I have called local TV service centre, and I was told min. charge is $500 plus $110 for pickup. It is out of the warranty now (almost 3 years old), I really don't know what to do.
Jan 15, 2011 | Hitachi P50H401 50 in. Plasma HDTV
I have replaced the lamp.Now the lamp wont come on and tv shutts
Did you replace the lamp cover after replacing the lamp? Make sure the cover is properly installed.
Jan 21, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Polaroid purple screen
I started to experience this problem as well. Eventually one day I turned my screen on and all the colors were crazy. Purple, Blue Yellow Green. I thought my TV was broken but then I noticed as well that the menu was not displaying the same issue. After messing with the menu for about 30 minutes I found the solution.
Go to SETTINGS. Then go down to DEFAULT. Select default and everything will be fixed.... for now. I think unplugging the TV over and over screwed up the settings. Hope this helps.
Oct 20, 2008 | Polaroid FLM-323B Television
Philips 60
First of all,this is a major labor intensive repair on Philips TV's changing the blue CRT because the new CRT does not come with the coolant that is sealed between the lens and the tube.If you have never done this type of repair before you should not attempt. Changing the convergence board is one thing (you can solder in two STK392-120 IC's and repair the board instead)
but changing the CRT's can be a nightmare.If you are brave go to PARTSTORE.com and get the parts $600+ (I would order the service manual too...you will need it)
Aug 27, 2008 | Philips 60PP9202 60" Rear Projection...
Did you change any of the 6.8 ohm 1watt resistors with the ICs? That chassis always blows at least two of the 6.8 ohm resistors often four of the 6.8 ohm. And you cant always tell by looking at the resistors , they have to have one side unsoderd and lifted from circuit. There are 11 of them 3149 - 3160 are the 6.8 ohm resistors that need to be checked.
Jul 19, 2008 | Philips 43PP9202 43" Rear Projection...
Apr 29, 2008 | Philips 43PP9202 43" Rear Projection...
Problems with my Phillips Rear Projection TV!!
have the coolant (glycol) in the CRT's....not as expensive as buying a new set...and sounds like it should be good as new if thats the only problem you have with it.
Jul 16, 2007 | Philips Magnavox 51MP392H Rear Projection...
Blue Haze
thats how my stared than got worse i call for service and got fix after 4 moths had the same problem and i called the same guy again at firs he told me that the convergence was bad and replaced them i think there are three pieces but than the second time he took the box inside the tv he checked all the circuits and the board and he found out the something else was getting real hot and was causing that the convergence to bad now he fixed hope i got no more problems
Apr 30, 2007 | JVC AV-65WP55 65" Rear Projection...
TV won't turn on immediately
Right now it should not be expensive to repair,the symptoms point to loose solder conection and it has gradually become worst,if you take the set to the shop it should cost less.What happens is the 10 legs the vertical ic has get overheated and loose,to prove this tap on the side of the set just to see if it reacts,it should also be check for other overheated areas while in service.If the quality of the picture is good then is worh repairing.
Sep 30, 2006 | Toshiba 27A62 27" TV
Philips 43PP9202 43" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
