Question about Sanyo DS13204 TV
Switch t.v. input to play games
I would like to play games on my t.v., but I lost my remote. Can I switch the input from the t.v. until I can get a new one?
  • Sanyo Master
  • 5,568 Answers
Your set is probably old enough to have a code set on most "universal" remotes.
I don't know in which country you reside but remotes for under $10 US are available from nearly any major store such as Walmart or Target and I suspect at equivalent stores elsewhere.
Posted on Apr 29, 2008
How to switch tv over to play games on wii
press menu button and look for source or input and manually do it onscreen, different buttons scroll through choices, enter button selects choices
Aug 20, 2012 | Toshiba 30HF66 30" TV
Trying to connect a Sega Genesis. I know it's connected properly to the place where the cable wire goes and then that is connected to the connector. What channel do I go to to play the games?
The input from the Sega wont be on any channel number - you need to select the correct input for the Sega using the "INPUT SELECT" button on the Symphonic remote control supplied with the TV. Switch on the TV the Sega, then press this button repeatedly until you can see the picture from the Sega.
- If you are using the sockets on the BACK of the TV, the correct input is "VIDEO 1"
- If you are using the sockets on the FRONT of the TV, the correct input is "VIDEO 2". You can also switch to the "VIDEO 2" input by pressing the "GAME" button on the Symphonic remote - if you still have it.
If you don't have the Symphonic remote, look for a button marked "INPUT" or "SOURCE" if you are using a universal remote.
If you don't have any remote for the TV, you will only be able to use the sockets on the front of the TV. You will then need to switch to "GAME MODE" by using the buttons on the front of the TV:
1. Switch ON the TV and the Sega;
2. Press the MENU button;
3. Press the VOLUME UP button to open the PICTURE MENU;
4. Highlight GAME MODE using the CHANNEL UP/DOWN buttons;
5. Set GAME MODE to "ON" using the VOLUME UP/DOWN buttons;
6. Press MENU again to close the menu
You should now be able to see the picture from the Sega. If not, check you have correctly connected the Sega to the TV. When you have finished using the Sega you will need to use the method above to switch game mode off again.
Hopefully, I've covered every possible angle. If you have a different Symphonic TV model from the one listed above (ST420FF), the method should be similar, but if you have any difficulty, please post back for further assistance.
BElectric.
Jan 16, 2011 | Symphonic ST420FF 20" TV
Hi, my RCA CRC311 BT turns on my Sharp television, changes the channels, etc, but it won't switch to video mode, even when I hit input. It is an old TV, but I used it to watch videos, dvds and play games...
Unfortunately you will not be able to switch input.
I also have a Sharp, I have tried 5 different universal remotes. None will switch input. I guess that function is not provided properly.
Sep 18, 2010 | RCA RCR311B Remote Control
Lost remote for DURABRAND TV. is there another button or function in tv that will lead me to the "input' or 'game' screen?
/the game fucntions should be accessable by pusing the channel up button until it appaers if not there are remotes for Durabrand they sell them at walmart as this is a wlmart line www.walmart.com and thanks for the ree question please vote accordenly
May 02, 2009 | Televison & Video
Playing Games
It you plug your video games into one of the inputs in the back or the front, you need the original remote that switches between the video inputs. Most of the universal remotes does not have this function so your best bet is to order the correct remote from Hitachi or part store. You may try the Logitech universal remote which may have the video input selector but not sure.
Jan 19, 2009 | Hitachi 51F500 51" Rear Projection...
Rca tv model f35673mb - lost remote.... switch to video ???/
I asume your game systems and dvd player are hooked up via the rca inputs.So all you would need to do is purchase a universal remote,program it for your tvand press ch00 which should be the video input.make sure your dvd or game system is on so you know if you are on the right channel
Nov 09, 2008 | RCA F35673MB 35" TV
How do I change to the front inputs to play video games w/o the remote?
There should be a button on the frame of the TV that say's input. or Source, Press that button until you have the game showing on the screen. Make sure the game is turned on before you start changing inputs..
Oct 31, 2008 | iLO 3200 32 in. LCD Television
Sonny Play Station 3
how is it connected to the tv? does your tv auto switch channels? if not try manually switching inputs with your tv remote (ext1, ext2, scart, hdmi etc etc) you say you connected to tv put in a disc right away? did you set up your console first? (of course point one about the display needs to be resolved before set-up can take place)
example if you are connected to your tv with an HDMI cable and your tv does not detect and then switch to your HDMI input.. use tv remote and repeatadly press button (maybe called source on your remote maybe something else) untill the input is switched to HDMI
Oct 18, 2008 | Sony Playstation 3 (PS3) Console
I own a symphonic 27" television
I had this problem on a symphonic 27 inch TV I just bought from a friend who no longer had a remote. The thing with the menu and buttons on the front of the TV doesn't actually change the TV to true game mode. I don't know what it acutally does, but it isn't really in game mode. When it is in true "game mode" you can't change the channels until you turn game mode off. What I did was bought a universal remote (a specific one that someone told me about) for 8 bucks at walmart and I was then able to switch to game mode with the Input select on the remote. The remote I bought that actually worked is this one: http://www.amazon.com/Philips-Magnavox-PM435S-4-Device-Universal/dp/B00006686A/ref=acc_glance_ce_ai_-2_1_tit/002-3174824-8273629
Make sure you look at it before you buy it and make sure it has a button that specifically says "input" on it. I know that some of the universal remotes don't have an input select button or one that doesn't work. As long as you get a Philips-Magnavox that has that button, you should be ok. Much better solution that paying 30 bucks for a new remote specifically for the TV. Hope this helps.
Mar 04, 2008 | Symphonic ST419E TV
Lost remote
Sorry, got to have the remote for this set...accordianman
Aug 13, 2007 | Symphonic ST420FF 20" TV
Sanyo DS13204 TV Logo
78 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
