Question about Epson Stylus CX3200 All-In-One InkJet Printer
Won't print Inherited printer from dad without manual. Have somehow changed setting to copy and can't get it back into print mode. Advice please.
  • Chic Maggie Apr 30, 2008
    I've reinstalled the Epson Stylus CX3200 softwear,and when it was done it said to try a copy which came out right but when I tried to copy from the computer their is no print that comes out
I Can"t seem to get my printer to print , I dont know if I may have clicked on something I should not have done. I am seventy seven years old and am not very computer sav vy hope you can help me Thank you
Posted on Apr 30, 2008
Computer says paper jam in printer but printer will make copies
Welcome to the ever popular-widely experienced world of:
PAPER SIZE MISMATCH!!!
YES! That wonderful world where unbeknownst to you but knownst to us (OK I watch Spaceballs WAY TOO MUCH) When you are sending a print job, somehow the paper size setting has been changed. Either in the printer itself, or in the print properties settings in your OS.
Double-check those paper size settings and try to print. If it still happens, try resetting the print settings in the printer back to factory default. Make sure you print out the printer configuration before resetting in case you need to reinstall those settings.
Nov 06, 2013 | HP PSC 1401 All-In-One Printer
I can't make a copy using the operator's mode. the copy that does print is so light and such small print thatit can hnardlyh be read. Also, the copy that comes oujt is only half of a page. Most of the
It sounds like the settings on your printer in the menu area have been set to reduce the image you want to print? Click on menu and then scroll the features with the up and down arrows and check on the size of the image to print and change it if necessary.
Please clairfy what you mean by "using the operators mode".
Oct 21, 2011 | Dell V305 All-In-One InkJet Printer
When I print 1 copy from my laptop, it will not stop printing many copies and I tried to copy a photo and there are horizontal lines on the copy. Jacques
The numbers of copies your laptop print out is set in your printer software.
You did probably forget to change the numbers to 1 (one copy).
If you use normal print paper for photos, it will almost always make horizontal lines.
Use photo print paper instead, then it won't happen.
It could also be that your print cartridges need a nozzle cleaning.
Normally your printer software has a mode to this.
Hope this will help you
Regards
Aug 29, 2011 | Kodak Cameras
My office Ricoh Cl2000n is mass printing pages when we only tell it to print one page. It has done this from multiple computers, so this leads me to think that it IS the printer and not the computer, any...
There is a setting in the menu, under Printer Features, that tells the printer how many copies to print of every document. Typically this is set to 1 by default, but maybe it got changed somehow. If you change that setting back to 1 and then reboot the printer, the problem should go away.
Aug 16, 2011 | Ricoh Aficio CL2000N Laser Printer
Printer is paused alert ribbon out after scrolling out rolls of ribbon, any attempt to re-align ribbon failed so far. Which printing mode should I be? print jobs make attempt to print but goes back to...
Locate your printer driver under devices and printers Right click on it and select "Printing Preferences" Choose the "Advanced Setup" tab Change media type to "Thermal Transfer" Be sure that "use printer settings" is NOT selected at the top left Click OK and you should be good. Note that any labels created prior to this change will need to be changed inside each label under the label setup.
May 18, 2011 | Zebra S4M Thermal Label Printer
My hplaserjet 1320 prints multiple copies when printing Excel Doc
The best thing to do as a starter is:
1. uninstall the print driver THEN
2. download the latest version from the manufacturer and install it
This rules out the driver as the cause of the problem
1. Go to printers
2. Right Click on the Printer HP Laserjet 1320
3. Click on Printing Preferences
4. Click on Advanced
5. Double Click (to open) on Paper Output
6. Ensure that COPY COUNT is set to "1"
If it is already set to one, trick the system a little:
1. set it to 2 and save that setting
2. then go back in and set it to 1
Good luck
Mar 15, 2010 | HP LaserJet 1320 Printer
My printer keeps printing greenish and blue/yellow
I fixed this problem for free with advice from the canon experts at the canon website, without them trying to sell me anything like a "plan" as your website has proposed.
Dec 03, 2009 | Cannon Canon i960 Photo Printer
My Hewlett Packard OfficeJet 500 was faxed a 45 page document, which I accepted (by activating the "Auto Answer" button) and printed. Then, while I was briefly out of the room, a second copy of...
I went back to Control Panel, and, following a hunch, found my way to discovering that the printer had somehow gone into "Pause" mode. I then simply clicked on the word, "Pause" and it converted to "Active."
Aug 15, 2008 | Office Equipment & Supplies
Changing Mode?
There is no way to change your machine into printer mode only. machine works in dual mode copier/printer.whenever you send a print from the computer, machine automatically receive the document and print it at the same time without changing the mode.like SCAN MODE AND HARD DISK MODE. So if you are facing a problem regarding printing then please check the paper size of the machine, and also check the paper size from the "PRINTING PREFERENCES" by taking the properties of printer icon in printer and faxes menu.(where installed printers shows) right click on the bizhub 200 printer icon and clickj on "properties". now click on "printing preferences" tab and then click on "size" tab, now from here check the paper size.its A4 or not if its not A4 then please change it to A4 then again give a print command.machine will start printing.
Jun 23, 2008 | Minolta bizhub 200 All-In-One Printer
Epson Stylus CX3200 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
