FixYa.com
Tags:
Bissell 1699 ProHeat Clear View Upright Steam Vacuum
I have misplaced the directions (by 2 users)
posted by bijou14 on Apr 29, 2008
I have misplaced the directions for the Bissell powersteamer powerbrush. I need the directions for filling the u tank etc.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on May 27, 2008
the water will not go in the bladder bag
Best Solution
posted on May 01, 2008
Helpful (85)
reddevil6
Rank:Guru Guru
Rating: 87%, 978 votes
Release the handle and lay the machine handle
back to access the Tank.
2. Remove the Tank from the base of the machine by
lifting the Tank carry Handle.
3. Carry like a bucket to the sink. Rotate the Handle
forward to unlatch the lid. Lift off and set the lid aside.
4. Fill up the Bladder with clean hot tap water.
*Do not boil or microwave water as it can
destroy the Bladder.
5.
Replace the top of the Tank by matching the lid
and tank edges. Handle must be in the forward
position in order to replace lid. Rotate the handle
to the carrying position to latch the lid.
Note: Remember to secure the lid and test to
make sure it is secure before picking up the Tank.
6.
Place tank into machine base, seating firmly in place.
Rotate tank handle back into latched position. Bring
machine handle back into upright position.
1.
Lift the formula Tank up and out of the machine base.
2. To fill the Formula Tank, first unscrew the Cap
and Insert. Always use genuine BISSELL formulas
to maximize cleaning and for the safety of your
machine. Fill formula up to the line and replace the
Cap and Insert. Place Formula Tank back into the
base of machine, making sure it is seated securely.
Note: If bottle leaks, check for proper positioning
of red gromment and straw.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Vacuums problems?
Bissell 1699 ProHeat Clear View Upright Steam...
i have a 1699 proheat
i have a 1699 proheat upright... Answer This...
Carpet Cleaner
i was cleaning my carpet and it... Answer This...
replace the switch that...
My carpet cleaner is not... Answer This...
BISSELPRO HEAT CARPET CLEANER
i have taken the top handle... Answer This...
Bissell Proheat
I need help installing a belt... Answer This...
Repair Service
Find Vacuum Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
