Question about Philips 43PP9202 43" Rear Projection Television
Tv comes on and shutts off immediately
I had a tv repaor guy come buy and look at my set and I told him what was happening. My blue was out of wack and like every other day the tv comes on and shutts right back off. Today he took out the STK392-120 ic's. So then he still tries to turn the set on. Will they work without the ic's? If so what wrong with my tv?
  • 293 Answers
Well no, it won't exactly work with out the ICS which is an internal control relay card. He most likely was thinking it was a power distribution problem. My suggestion is to look at the power supply and make sure nothing is bridging any of the circuitry. Just like a computer the on and off button is attached to a set of pins, and just like computer motherboards the controls also exist for a reset. And if anything bridges these pins turning on the unit will just cause it to shut down again. Also look for water damage and heating damage that might have caused problems with the power supply unit.
Posted on Sep 12, 2008
My television just went off! We tried to turn it back on but it wouldnn't come back oh. Finally the button flashed red like it was trying to come on and we heard 2 or 3 words then that was it.then the...
Tries tv unplug,replug it back like about an hour later.By letting the tv restting itself back to the factory setting.Now tv should be working again.If it have the same result.Yes,the power supply board is the problems and the causes.That the board,where the power a/c cord plug into it.Try website like to buy a whole refurbish power supply board for the replacement.
Feb 03, 2011 | Hitachi P50H401 50 in. Plasma HDTV
I turn on the tv then it turns back off on its own, ill click the power button then the solid blue light comes on, then it just shutts itself off right after.
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Aug 01, 2010 | JVC LT-52X579 52 in. LCD TV
Sony Wega Trinitron HDTV Blue Screen with Sound
Had similar problems with HD cable on dvd. swapping with another cable solved the problem.
Aug 11, 2009 | Televison & Video
I have replaced the lamp.Now the lamp wont come on and tv shutts
Did you replace the lamp cover after replacing the lamp? Make sure the cover is properly installed.
Jan 21, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Polaroid purple screen
I started to experience this problem as well. Eventually one day I turned my screen on and all the colors were crazy. Purple, Blue Yellow Green. I thought my TV was broken but then I noticed as well that the menu was not displaying the same issue. After messing with the menu for about 30 minutes I found the solution.
Go to SETTINGS. Then go down to DEFAULT. Select default and everything will be fixed.... for now. I think unplugging the TV over and over screwed up the settings. Hope this helps.
Oct 20, 2008 | Polaroid FLM-323B Television
Did you change any of the 6.8 ohm 1watt resistors with the ICs? That chassis always blows at least two of the 6.8 ohm resistors often four of the 6.8 ohm. And you cant always tell by looking at the resistors , they have to have one side unsoderd and lifted from circuit. There are 11 of them 3149 - 3160 are the 6.8 ohm resistors that need to be checked.
Jul 19, 2008 | Philips 43PP9202 43" Rear Projection...
he was checking to see if the set stayed on with the ICs out if it did the ICs are shorted. Its easier to unplug the convergence yokes and try it but some techs do it differently
Apr 29, 2008 | Philips 43PP9202 43" Rear Projection...
Problems with my Phillips Rear Projection TV!!
have the coolant (glycol) in the CRT's....not as expensive as buying a new set...and sounds like it should be good as new if thats the only problem you have with it.
Jul 16, 2007 | Philips Magnavox 51MP392H Rear Projection...
Blue Haze
thats how my stared than got worse i call for service and got fix after 4 moths had the same problem and i called the same guy again at firs he told me that the convergence was bad and replaced them i think there are three pieces but than the second time he took the box inside the tv he checked all the circuits and the board and he found out the something else was getting real hot and was causing that the convergence to bad now he fixed hope i got no more problems
Apr 30, 2007 | JVC AV-65WP55 65" Rear Projection...
TV won't turn on immediately
Right now it should not be expensive to repair,the symptoms point to loose solder conection and it has gradually become worst,if you take the set to the shop it should cost less.What happens is the 10 legs the vertical ic has get overheated and loose,to prove this tap on the side of the set just to see if it reacts,it should also be check for other overheated areas while in service.If the quality of the picture is good then is worh repairing.
Sep 30, 2006 | Toshiba 27A62 27" TV
Philips 43PP9202 43" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
