Question about Panasonic DVD-LS50 Portable DVD Player
Panasonic DVD-LS50 Does Not Turn ON
I have a DVD-LS50 but for some reason it does not Turn ON. It only seems to work when the charger is connected but without the charger it does not work.
Can anyone please help me with a solution.
  • bablu121 Apr 29, 2008
    Thanks for the response. I suspect the battery has died that is why the DVD does nto start up. Do you know any good website where I can buy a replacement CGR-H701 battery?
    Thanks once again for your help.
    Sergeant:
  • 154 Answers
Sir, i think the battery is faulty... if you want to replace it will cost around approx $48.. you can buy from http://www.abatterypack.com/dvd-player-battery/CGR-H703.htm... they are offering one year guarantee. thank you.. dont forget to rate me..
Posted on Apr 30, 2008
    Scholar:
  • 131 Answers
I suspect the battery is bad.see if you you can disconnect the battery then try it. I hope this is what you need if it is not let me know we use to fix a lot of these at my shop.
thanks doctorvideo leadingedgeelectronics since 1987
Posted on Apr 29, 2008
Unlock region code
How do I unlock region for a region b Samsung bd d5100 blu ray player so I can play all regions
Jan 01, 2014 | Panasonic DVD-LS50 Portable DVD Player
Portable dvd player h03 what to do fix it?
this error code means that there is something wrong with the laser lens most portable dvd players over time get weak motors or lenses you may try to take a small cloth or cotton ball and move the lens back and forth from the spindle to the end then place it as close to the spindle as you can then turn it on and you might be good to go! if not then you have a bad motor and may have to replace it! hope this helps!
Dec 18, 2009 | Panasonic DVD-LS50 Portable DVD Player
Pls help
H03 error means Traverse servo error. The spindle motor may be defective.
Mar 28, 2008 | Panasonic DVD-LS50 Portable DVD Player
DVD-LS5 portable
The spindle motor is defective.
Mar 21, 2008 | Panasonic DVD-LS50 Portable DVD Player
DVD player
Sorry, no can do...accordianman
Feb 22, 2008 | Panasonic DVD-LS50 Portable DVD Player
LG LS50 DVD/CD-RW DRIVE won't recognize blank dvd-r
Yes does not read DVD-R because if your LS50 Labeled like this (DVD/CD-RW) means that can read only all DVD Disc and cannot write on DVD blank only CD blank.
You can burn only on the blank CD-RW or any blank CD.
Jan 17, 2008 | LG X-Note LM50 Notebook
Error code on Panasonic LS50 portable DVD player
I purchased my LS50 over 16 months ago. I had a H03 error before and it went away after sitting on the shelf for three days. It worked ok for another couple of months and then stopped again. The screen says reading but the motor is not spinning. i pointed out that the laser lens is in the wrong place. When at resting location, the lens should be parked near to the spindle in the middle. The mechanism to move the lens backward and forward sometime get stuck at the end of its travel - furthest away from the spindle. If your player is out of warranty, then you maybe able to try this. Open up the bottom cover by taking out the screws - 10 or so. This will reveal the lens and motor module. Flip over the model and you should see the gear and shaft for the lens. Move the gear so that the lens move towards the centre. Click the covers back into place , reconnect the battery and try. If it works, put all the screws back. Mine was fixed this way but this is not a gaurantee that this will work on yours. Good luck.
Forgot to mention. You can also clean the gear shaft in case there are small particules stuck to the grease and affect the movement. After cleaning, apply a tiny bit of grease just to lubricate the moving shaft. Not too much. I am glad that the instructions help.
Nov 25, 2007 | Panasonic DVD-LS50 Portable DVD Player
Ls50 dvd drive
There is a light on the dvd drive does this flicker when the computer is booting up? The cable may have come unattached? Normally winxp recognises any dvd hardware falty or not. You might need to get inside it and look!!!
Oct 06, 2007 | LG X-Note LM50 Notebook
Panasonic Portable DVD Player LS50
Can you see or hear that the disk is spinning up normally as it did before? I understand that the small, spin-motors on these portables often go bad.
Jun 06, 2007 | Panasonic DVD-LS50 Portable DVD Player
Panasonic DVD-LS50 Portable DVD Player Logo
101 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
