Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
Error code 061 and the ADF door is closed
I am getting Error code 061, telling me to close the adf door. The door is closed, I have turned it off, unplugged it and am still getting the error code.
    Scholar:
  • 159 Answers
In this case make sure that the plastic tab that actuates the sensor is not broken off. If it is, try and find some way to defeat it. Other wise you will have to replace the whole transmit door assembly.
Posted on May 27, 2008
  • bren Aug 01, 2013
    Rob, where is the plastic tab located?
Error code 005-301
Please try the following
- Lift the cover to expose the flat bed scanner glass.
- Under the cover, there is a long white bar with two white tabs perpendicular to the white bar.
- One of the tabs could be retracted. Pull on the tab until it is fully extended.
Error "Cover Open 005-301 Close ADF Cover" and solution is Close the cover of the ADF
Jul 23, 2014 | Dell 3115CN
Hi I'm getting a lower case "c" error code on my fi-6130z. Anyone know what might it be?
Hello Steve,
The flashing "c" on your fi-6130z scanner panel indicates that the ADF was opened when the status was ready("1"). To return to ready("1") status, close the ADF. If the display doesnot return to ready ("1") after closing the ADF, turn the power off then back on. If the problem still persists, you are recommended to contact an authorized FUJITSU scanner service provider or the dealer where you purchased the scanner.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Aug 08, 2013 | Fujitsu fi-6130z - Document scanner -...
I have a Cannon Pixma MX320 all in one printer and I cant get it to stop saying document in ADF
Issue: ERROR LCD: DOCUMENT IN ADF
Solution: Remove foreign object from the Automatic Document Feeder (ADF) - MX310
Check the Automatic Document Feeder (ADF) for obstructions
Follow this procedure to check the ADF for obstructions. You do not need to turn off the power when clearing document jams.
Document jams in the ADF (Document Tray)
  1. Press <Stop/Reset>.
  2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
  3. Remove the jammed page from under the roller to the Feeder Cover side.
  4. Pull out the jammed document from the ADF. If the document cannot be easily pulled out, proceed to section Document jams in the ADF (inner side).
  5. After removing the jammed document or if a document is not jammed, check the document feed area to make sure there is no foreign material. If you find foreign material, carefully remove it.
  6. Close the Feeder Cover.
    Note : If documents remain in the ADF after pressing the Stop/Reset button during scanning, "DOCUMENT IN ADF" appears on the LCD. Press the OK button so that the remaining document is automatically fed out.
    When rescanning the document after clearing the error, rescan it from the first page.
    Note: The document may not feed properly depending on the media type, or your environment, such as when the temperature and humidity are either too high or too low.
    In this case, reduce the number of document pages to approximately half of the loading capacity. Another alternative is to scan from the platen glass
  • If documents remain in the ADF after pressing <Stop/Reset> during scanning, [Document in ADF] will appear on the LCD. Press <OK> so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
  3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
  4. Open the Document Cover and pull out the document from the inner side.
  5. Close the Document Cover.
    Note: When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (Document Output Slot)
If the document is jammed in the Document Output Slot, pull it out.
pulloutofslot.gif Note: When rescanning the document after clearing the error, rescan it from the first page.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Canon PIXMA MX310 All-In-One Printer
Fi-6130 not grabbing paper, displays Code: DS32002
My scanner is Fujitsu M4097D. I just have problem with ADF: Error Code DS32002: Paper jam in the ADF. Here is my solution: 1. Bend two white platin pieces down a little bit in order to "sensor" the paper scanned. This problem is occurred after I am scanning 50 thick pages. Until paper count 42, it is stopped with error code DS32002. Hope help anybody having this problem.
Jan 06, 2010 | Fujitsu ScanPartner fi-5120C Pass-Through...
I've got a new hp m2727nf laserjet (3 weeks old), and an error message "ADF door is open" appears in the product display. I have turned off and unplugged the power several times, I've removed the adf and...
From HP's web-site:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=3377075&prodTypeId=18972&prodSeriesId=3377075&objectID=c01236058
Make sure that the ADF lid is closed.
Remove the ADF and reinstall it.
If the message persists, turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the product to initialize.
If the error persists, contact HP. See www.hp.com/support/LJM2727 or the support flyer that came in the product box.
Dec 05, 2009 | Computers & Internet
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
Error U20
U20 indicates the ADF cover is open, look to see if something is preventing the ADF cover from closing, like small piece of paper or something out of place.
Apr 27, 2009 | Panasonic Workio DP-2500E Copier
ADF DOOR OPEN CODE = 061
Remove the beige cover where the paper comes out and close the gray door.
Mar 17, 2009 | Office Equipment & Supplies
Error msg..."close ADF cover". Where is it?
Adf : auto doc feeder
the top that you put the pappers in to copy mare than one sheet.
make sure all doors are closed.
lift doc feederas if making copy on glass look where the hinges are there should be a plunger next to one of them, that is the switch to tell it if it's open or flat. try pressing it down to see if message goes away, it may need adjusting.
Jul 15, 2008 | Ricoh Aficio 1013F Copier
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
158 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
