Question about Jenn-Air JMV8208AAS Microwave Oven
No power on Jenn-Air JMC 7000 ADB Microwave
Still looking for solution. Jenn-Air JMC7000 ADB Microwave. No power, no clock, no nothing although regular oven combo still works. Is there A fuse or a reset of sorts? Will buy new if it can't be fixed but would like to fix it first.
no power
  • Jenn-Air Master
  • 9,098 Answers
It's either the fuse or the thermostat on the magnetron.
You can download the service manual here.
You can also find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 02, 2008
My microwave stopped working suddenly. The front pannel is not working and even its clock is off.
I would suspect the fuse first, then the magnetron's thermostat second.
The full service manual for the JMC7000 is here.
You can order parts from the Pros here.
Dec 27, 2012 | Jenn-Air JMC7000 Microwave Oven
Looking for an exact size replacement for Jenn Air JMC7000
it looks like the Magic Chef MCD1611 is the same size
Jun 16, 2011 | Jenn-Air JMC7000 Microwave Oven
JMC7000 No turntable, interior light or microwave function. Just the clock, timer and keypad functions...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 24, 2010 | Jenn-Air JMC7000 Microwave Oven
No power in the microwave. It is as if you unplugged it. Is there an internal fuse in the unit? There is power to the unit. The unit shows nothing on the panel and when you open the door, no light comes...
If you look at the back of the oven there are usually small fuses or breakers back there. Check to see if that is the issue. Also if you haven't already make sure the wall outlet is functional.
Dec 14, 2009 | Jenn-Air JMC7000 Microwave Oven
JMC 8100ADB
Check the capacitor with an ohmmeter, if the meter reads 0 ohms the capacitor is bad and needs to be replaced. More likely, though, the magnetron is bad.
Sep 23, 2009 | Jenn-Air JMC7000 Microwave Oven
Jenn-Air JMC7000 Microwave stop working
I have the same unit and age the JMC7000 everything appeared normal on the display and countdown etc...But it would not heat,I trouble shooted the problem and discovered it was a faulty door switch I replaced it and it works like new again.I ordered the part from www.repairclinic.com it's an easy fix.and costs a few bucks...
Dec 19, 2008 | Jenn-Air JMC7000 Microwave Oven
I have a different Jenn-Air built in microwave & oven combination but I'm sure my solution will work for you as well.
My microwave was plugged into an outlet located on the top of the oven. This outlet has a "circuit breaker" that tripped while we were using the self cleaning feature on the oven. You just need to reset the breaker button right next to the wall oven outlet. Why it tripped is a mystery since the microwave was not in use at the time. Bad design.
Of course, getting to the reset button is your only challenge. You need to pull the microwave and oven out of the wall/cabinetry in order to get to it. The unit is heavy so you will need help. Or, call a certified repairman and they should be able to do this for you in 30 minutes or less so the service call should not run you more than @$85 if it is no longer under warranty.
I would also suggest you contact Jenn-Air to complain about this issue and seek reimbursement from them if necessary.
Dec 18, 2007 | Jenn-Air JMC7000 Microwave Oven
Jenn-air microwave JMC 7000 ADB has no power
Dec 17, 2007 | Jenn-Air JMC7000 Microwave Oven
Jenn-Air JMV8208AAS Microwave Oven Logo
216 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
