Question about Refrigerators
Fridge not cold but freezer working
Do you think its the defrost heater. what is the bi metel?
    Genius:
  • 1,073 Answers
Call me at 276/523/4434
Posted on Apr 29, 2008
Hotpoint fridge not working
The first thing you want to do is open the freezer and see if the fan inside there is running. The reason is the freezer cools the refrigerator side by circulating air from the freezer. If the fan is running then your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
May 27, 2012 | Hotpoint FFS90 Bottom Freezer Refrigerator
Model TFX30PP purchased 9-10 years ago. The refrigerator & freezer are not cold enough. There was frost built up in the back of the freezer. We defrosted it. Plugged it back in - fridge read in the...
What you have is either a bad heater or heater bi-metal thermostat most likely. I say that since the ice box is working correctly until that frost builds up. Have you checked them. Your heater should test good for continuity(not open or bad) but the bi-metal is a different story. It is open at 50 degrees f and it only closes or carrys voltage when it is sitting in a freezer at 25f. What it does is allow power to the heater when the timer or automatic control calls for defrost. The defrost cycle is around 20 to 40 minutes and power is constantly being sent to that heater the whole time. When it gets warm enough for frost to melt 50F then that bi-metal opens up and kills the power to that heater. If that heater was to stay on it would not be purty. For the rest of the defrost cycle the coils simply rest and drip.
Jun 09, 2010 | Refrigerators
IFrost Free Sharp Refridgerator & Freezer-Fridge not keeping cold
hello sir/mam
please check the blower of the refrigerator if this is not working the refrigerator wont get cold.
Sep 14, 2009 | Refrigerators
Kenmore 15.2 upright freezer coils freezing up
Check the bi-metal switch. when cold, it should have continuity also.
If both heater and bi-metal are good, change the defrost timer
I hope this helps.
Please leet me know if I can assist you further
Vic
May 31, 2009 | Freezers
Freezer cold, fridge warm
Hi, You have a self defrosting problem.
Remove the rear inside freezer panel and check continuity on the defrost element and bi-metal switch.The bi-metal has to be tested cold. If there is continuity on both parts, you will need to change the defrost timer.
The most common part that goes bad is the element. I hope this helps you. Please leet me know if I can assist you further.
Vic
May 28, 2009 | Hotpoint HSS25GFP Side by Side...
Indesit BA139 fridge freezer with very thick frosting on back wall, but not very cold fridge section (despite changing the temp control to max) and normal very cold freezer section. When temp control...
One or more of your defrost components(defrost timer or board, defrost heater, defrost thermostat/ bi-metal) are bad. Unless you removed the inside back wall in freezer and completely thawed the evaporator, it will not cool properly.
Aug 25, 2017 | Refrigerators
then remove the panel that has the frost on it the heater and bi metel will be there
Apr 29, 2008 | Refrigerators
is the fan running in the freezer, if not find out why, is there frost on the back panel if so you have a defrosting issue bad heater bad bi-metal or bad defrost timer let me know if you need any mor help
Freezer compartment of fridge freezer working ok but fridge section not cooling
ON ALMOST ALL REFRIGERATORS, THE FRESH FOOD SECTION GETS ITS COOLING FROM THE FREEZER BY AIR CIRCULATION. IF THE AIR ISN'T CIRCULATING, FINDING THE CAUSE WILL REMEDY THE PROBLEM. THE MOST FREQUENT FAILURE IS THE DEFROST CYCLE AND IS EASILY DIAGNOSED BY LOOKING IN THE FREEZER SECTION. IF FROST IS PRESENT ON THE BACK WALL, (OR FLOOR OF OLD MAGIC CHEF TOP MOUNT), THEN A DEFROST FAILURE HAS OCCURED. THERE ARE THREE COMPONENTS IN THE DEFROST CIRCUIT. THE CONTROL, THE HEATER, AND THE BI-METAL. FIND THE DEFROST CONTROL AND SET TO DEFROST. IF THE HEATER COMES ON, THE CONTROL IS BAD. IF THE HEATER DOES NOT COME ON, EITHER THE HEATER OR THE BI-METAL IS BAD.
TO FIND THE BI-METAL, FOLLOW ONE SIDE OF THE HEATER WIRE FROM THE HEATER TO A SMALL ROUND DISC WITH TWO WIRES COMING OUT OF IT. THAT IS THE BI-METAL.DETERMINE WHICH IS BAD WITH VOLTAGE OR RESISTANCE MEASUREMENTS.
Mar 27, 2008 | Refrigerators
Fridge doesn't get cold enough
you have either a Defrost heater / a defrost timer/ or a defrost bi-metal that is bad. if you post your model # i can look it up and show you how to set it into defrost to see if the heaters are ok
Since you replaced the timer already that leaves two things you need to check set it into defrost if you know how and remove the panel in the back wall of the freezer you should see the heater(s) are on if not check pwr 120vac at the heaters if 0 volts the bi-metal is bad
Feb 22, 2008 | GE GSS25LGM Side by Side Refrigerator
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
