Question about Kicker KX800.2 Car Audio Amplifier
Kx800.2 kicker car amp
I have akicker kx-800.2 amp it works but some times sub goes out and then secounds later it kicks agian
  • 975 Answers
TWO THINGS : first check that amp has a good ground , I mean connected to the chassis of vehicle .
second , check the connections of the speakers , it could be Unbalance , meaning not matching the value in OHMS of AMP with value in OHMS of speaker,
you will need a multimeter for this task . hope this helps
Posted on Apr 29, 2008
So I have the first kickers that came out the 15 will a 800 watt amp push um without eather blowin out
If you are referring to the Kicker L5 solo-baric subwoofer, then an 800 watt peak amp will not blow even one of those subs. The L5 is capable of handling 1000 watts peak and 500 wrms. An 800 watt peak amp will usually have around 400 wrms. Underpowering the subwoofer will not hurt the amp or the sub(s).
Mar 07, 2011 | Car Audio & Video
BP1200.1 Car Audio Amplifier: is that amp good for 2 12 inches subs kickers 600...
that will most definitely be the best amp you will own and the only amp you will ever need to purchase.
May 13, 2010 | JBL BP1200.1 Car Audio Amplifier
I have a 12 kicker sub and a 600 wt power acoustic
there is a volume on the amp try that and the settings on your deck allow you to adjust your subs
Jan 15, 2010 | Kicker Car Audio & Video
I've been running a kicker kx 800.2 and it has worked until now
Hello highryguy420,
It sounds like one or more of the output components is failing on the amp. You can contact Kicker support directly for instructions to return the amp for repair: support@kicker.com . Alternatively, if you have a local car audio shop that does component level repairs, they could perhaps save you some money and time.
Hope this helps.
Jul 14, 2009 | Kicker KX800.2 Car Audio Amplifier
Protection light comes on went the amp is turn on and it stays on for four seconds and then the amp turn on
Disconnect any speaker from the amp then re-power. If it still goes into protection, your amp needs serviced. Shorted output transistors most likely. And check your Sub for shorts as well. If the voicecoil on the sub is burnt, it will short any amp. If you can use a meter, check the resistance on the sub. Hope this helps
Jun 02, 2009 | Kicker KX Series 04KX1200.1 1200w RMS...
Amp goes into protection
make sure the impedance is right for the amp you're using. If you're using a 4ohm amp and a 2ohm sud that may be the problem. It may be overdriving the amplifer which is bad and can cause damage to the amp. Hope this helps.
Jun 01, 2009 | Kicker 12" Solo X Subwoofer S12X - 5000...
Does a 1200W amp run 2x800W subs
ya youll be fine 800watts is at peak power on the speakers
May 29, 2009 | Kicker KX Series 04KX1200.1 1200w RMS...
Best amp for Kicker Sub
Hello dalex7,
The Kicker 08ZX400.1 would be a great amp for your subwoofer. It will work into a 4ohm load with no problems.
But you can buy an amp with more power, looks better, has a smaller footprint, and cost less than the 400.1. I'd look at the Alpine MRP-M500. Take a look at it here at Crutchfield. The M500 is also easy to install, runs cool, and is very efficient.
Hope this helps.
May 21, 2009 | Jl Audio CVR12 Kicker 12" CompVR Series...
Amp protection
Does it go into protect if you disconnect the speaker wires from the speaker terminals of the amp?
Feb 16, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
What amp to use
recommended maximum for the sub boxes is 1600/800 here is the link to the manual if you need it; http://www.kicker.com/06/tech-support/manuals/manuals/2007/2007%20CompVR%20Box%20d01%20Web.pdf If you really wanted to get the maximum from your subs then a zx750, or possibly a zx1000 would be the ideal choice. Either amp you suggested will work, but you will have more fun with a 750 which should do fine. Hope this helps :)
Mar 17, 2007 | Kicker ZX400.1 Car Audio Amplifier
Kicker KX800.2 Car Audio Amplifier Logo
74 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
