Question about JVC C-13811WT 13" TV
Tuning or programming?
MY JVC C-13811 which I just had running in my bedroom was fine but after moving it to my office, I can't figure out how to get it working again. The picture is just blue with the channel 02. I hit Menu button and tried auto tuning and saw it run through the numbers but it just comes back to bright blue screen with channel 2 on it. I thought maybe I didn't screw the cable line in tight enough but have retried and can't figure out the problem.
  • deweyry Dec 07, 2008
    jvc c-13811
  • 71 Answers
No tv signal at this outlet for cable. make sure center conductor of cable is coming through at both ends-may have been pulled away from wall outlet.
Posted on Apr 30, 2008
On my jvc tv model hd-61g787 I cannot program channels
you can program channel either in the remote control or in the tv button panel. press menu then go to manual fine tune so you can program the channel one by one. you can use the volume up/down button to tuned the desired channel. to select channel use the channel up/down button.
Jun 01, 2013 | Televison & Video
I have 2 alba tv/dvd combi's.1 in kitchen & 1 in bedroom.After digi switchover 1 in kitchen is fine after re tuning.The bedroom tv only has a few stations after numerous re tunes.Both work off
The one that does not work: have you tried to unplug it for a while from power and plug it back to see if it will reboot and allow you to program?
Apr 08, 2012 | Televison & Video
Dish Network installed a new receiver (with the old receiver needed to be replaced). For the past 10 years that we have owned our ProScan....the dish has operated fine. Now with this new receiver, the...
Hi cjichel1830,my name is Mike Houston of DISH Network and I was going over your post and seewhere the new receiver won't auto-tune. With the new receiver if the remote hasnot been programmed to the new receiver and TV it will not work. I will giveyou this link http://www.dishnetwork.com/SupportSection/setup-receiver-totv,and it will help you with the setup of your new receiver and remote, if youhave any questions please e-mail me at michael.houston@dishnetwork.com.
Feb 08, 2011 | Proscan PS32700 32" TV
REMOTE FOR JVC C-13811 TV WON'T WORK....WE THINK ITS THE 4 DIGIT CODE, BUT WE CAN'T GET TO WHERE WE NEED TO RESET IT...WHAT CAN WE DO?
As far as I am aware, the code is only for preventing rated channel viewing. Can the TV be turned on/off with the remote? If not, either the remote or the TV is defective. Check battery, check TV/DVD/SAT switch on the remote's side or front, is there any switch in the battery compartment? If the battery is good and the remote is functional, you may check it by holding it towards the your cell phone camera while pressing any remote button. You should see a bulb lights when any key is pressed. Our naked eye cannot see it but the camera can. To make sure the test works, use another remote. If the JVC remote test fails with good battery, change the remote. If the test shows good, then the TV's remote sensor could be defective.
Jan 23, 2010 | JVC C-13811 TV
Screen looks like a picture negative, PIP works fine, sound fine
Sony's have dual tuning systems to allow for the separate PIP channel. The common problem on the Sony's is the circuit board and tuning module connections go bad. It is likely that the connections on the board or module were already in the decayed process and moving it just accelerated the issues that were inevitable.
The quick fix is to swap the PIP over to the main picture or to bus the antennae signal to the antennae B terminal thus bypassing the bad tuner module.
The recommended fix action is to have someone with soldering skills to remove the chassis, and locate all the cold and cracked solder joints, especially near the tuning modules. If this does not take care of the problem, the tuning modules will need to be removed for re-soldering on the actual tuner modules.
If none of the above works, then you can always use the audio/video outputs of a cable box or vcr to the a/v jacks of the tv, thus bypassing both tuners in the tv.
Apr 28, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Moved tv from 1 location to another
hi there, it may need some fine tune for the sony kv-27fs12 to be connected directly to cable jack wall. do some test. ty
Jan 10, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
DVDs won't play (but CDs will)
Did you try to clean lenses on laser head?
Sep 28, 2007 | JVC FS-S77S DVD Micro Component Stereo...
Mitsubishi CS-35505
Had the same issue. Try hitting the input button on the remote. Then chose aux. 1 option. Worked for ours.
Dec 28, 2006 | Mitsubishi CS-35505 35" TV
How to set a station with the remote control
1 Tune in the station you want to preset..(use >> >>
Aug 11, 2005 | JVC FS-2000 Shelf System
Televison & Video Logo
159 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
