Question about Kenmore 20172 Top Load Washer
Kenmore 80 series washer stopped during unbalanced spin cycle
Heard it clonking(unbalanced) during spin cycle went to check it tho' stopped spinning befor i got there...will fill but not agitating or spinning and/or draining....please help...thanx!
  • 5 more comments
  • hotmommy Apr 29, 2008
    ps...theres also an humming coming from the area where the water hoses connect to the machine...
  • hotmommy Apr 30, 2008
    ...any help still appreciated...thanx! hmmm...
  • hotmommy May 01, 2008
    you're right...it was the lid switch...running great again so thank-you very much for your assistance "o-fixer" i'm happy to find you here you really saved me lots...thanx again!!! hm
  • Anonymous Nov 24, 2008
    I have the same problem. How do you fix the lid switch?
  • Anonymous Mar 25, 2014
    in spin cycle load is unbalanced
  • Anonymous Mar 29, 2014
    I also accidentally removed the grey button that the lid sits down on to begin cycle or shut stop cycle
  • Anonymous Mar 30, 2014
    Washer fills and washes but stops at the spin cycle and makes a whirring sound.
    Genius:
  • 1,028 Answers
Lid switch is broke lever probley broke off or screw holes broke out due to off balance load forcing tub over against switch lever
Posted on May 01, 2008
I have a kenmore 800 series washer that makes a loud slamming noise at the end of the spin cycle. If you lift the lid during the spin cycle the basket slams to a halt immediately. It actually moves the...
Those parts you can check
1/ strings holding the drum were broken causing drum unbalancing when it spins.
2/ Drum bearing also gone. (noise)
3/ 3 slides that located underneath the triangle frame need replaced.
Oct 22, 2013 | Washing Machines
No spin cycle
This is usually caused by the pressure switch. Here is a link with the other possible problems. To check the pressure switch follow the link to the video. http://appliancehelponline.com/topwashernospin.html
Jul 16, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer Series 80. The cycle stops before
check to see if you have it set on drip dry
Feb 06, 2010 | Kenmore Washing Machines
Makes a loud banging noise as if the load is underbalanced even through the load is balanced.
HI There
Try this even tho you said it's balanced. Sometimes it looks like but a slight unbalanced can cause this problem.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Let me know how this goes and thank you for writing to fix ya.
Best Regards Richard
Jan 07, 2010 | Kenmore Washing Machines
Excessive noise during the spin cycle. we have owned the washer for 16 months. problem started 1 wk. the machine is level.
Jan 03, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore washer 80 series misses spin during wash.
You may need to replace the motor coupling between the pump and motor...
Apr 07, 2009 | Kenmore Washing Machines
Kenmore series 80 washer makes loud knocking noise during spin cycle
Most washer tubs are suspended by heavy rubber O-rings. These do fail with age so that the tub is not being held centered anymore. I suspect one of them has failed or come off during a severely unbalanced load.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer series 70 shakes wildly during spin during cycle
I have the same kenmore and have experience this before. It is unbalanced. Get a spirit level to check for balance. To rebalance, empty the washer (so it's not heavy), lean over the washer and grab the back, tilt it forward and the auto balancing legs should reposition themselves. Re-check for balance using the spirit level. If still out, adjust the front feet of the washer by screwing the legs up or down (using a wrench). This will cure the problem (unless you have a very unbalanced load of towels for instance). Good luck
Mar 30, 2008 | Washing Machines
Kenmore 20172 Top Load Washer Logo
694 people viewed this question
Sal De
fordexpert
Robert Rankin
