Question about Kenmore Oasis HE 27082 Top Load Washer
Washer keeps reading Du
The washer machnie keeps displaying the du code and will not allow the lid to open ... we gave tried to reset the machine and turn it off many times but the lid will not unlock and open .. wat should we do ????
    Genius:
  • 1,028 Answers
Sounds like lid lock failure clips each side just below top eadge of washer about 3-4 insches from outside edge use stiff putty knife to push clips in and release top should be able to acess switch from there swtich will need replacing
Posted on May 01, 2008
Error code " du "
DU = Door Unlock code
Washing machine displays error code F/DU after six attempts to unlock.
-Door lock assembly failed.
-Test door lock switch
-Visually inspect wire harness connection on CCU, Door lock assembly, replace door lock assembly.
The door lock assemble on this washing machine can be replaced from either the top of the front. The door boot can be removed or the top of the washer can be removed.
Hope this helps.
Jun 22, 2011 | Washing Machines
I have a du code that will not go off and the door is locked.
The F30 error code (dU) will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
TEST #8 Door Lid Lock
Perform the following checks if washer fails to lock (or unlock).
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I am getting the code on my frontload washer F du, it is making a clicking sound the water starts to fill , then the code comes up..I am not able to find this code in my manual ..I am thinking that maybe...
The DU in the display is an error code for the door lid not unlocking. This is an indication that the lid lock assembly has failed or the control board is unable to determine if the lid is unlocked. This usually indicates that the lid lock assembly will need to be replaced.
http://www.servicematters.com/maytag_library/docs/16007803.pdf
Service manual above.
Jun 01, 2010 | Kenmore Elite 45986 Front Load Washer
Lid lock won't release ?
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
May 27, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Du f flashes as code on whirlpooll whasher??
Door Unlock Error
If it is a cabrio:
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Du code
According to the Whirlpool installation and maintenance manual:
“dU” (Door/Lid cannot unlock)
Is there excessive weight on the lid, such as
a basket of laundry? Excessive weight will
keep the lid from unlocking. Press PAUSE/
CANCEL once to clear the code.
Sep 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Du error code on whirlpool cabrio
that code is for the door unlock error. is it possible that you may have tried really hard to open the units lid when it was locked? if so the door lock may have been broken. if not, then try to unplug the unit for a few minutes and try a new cycle.
if the code comes up again then you will have to call for free service as it has a 1 year warranty for parts and labor. yes even if you broke the lid lock!!! dont worry it happens when you get something new and are not sure how it works.
Dec 29, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore front loading washer
brand new and you changed the latch mech.? door latch or lock asm.? DU is door unlock error, it tried to unlock and cant. usually replace lock asm (inside machine) for this problem. may have latch out of alignment.
Dec 01, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
117 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
