Subwoofer keeps turning onto stanby? - Audio Players & Recorders
I had this "problem" and corrected it by slightly increasing the volume on my receiver. After a bit of tweeking both the volume on the receiver and the output level on the sub everything seems to be okay.
Posted on Apr 29, 2008
What is the problem if the stanby indicator flashes red and doesnt fire up?
First disconnect all the speakers.
See if the unit will fire up after disconnecting it from the power for 1 hour or more. If it does you have a short in your speaker wiring.
Check your connections and reconnect if it fires up.
Now refer to page 129 of your manual.
If the unit does not fire up, press VCR/DVD, while keeping it depressed press the on button.
"Clear" should appear in the screen.
If clear does not appear or resetting to default does not allow the unit to fire up, then another Onkyblow has bitten the dust and is fried.
If it fires up after setting back to factory default, then you will have to redo your set up from scratch.
May 10, 2014 | Onkyo TX-SR608 Receiver
Tv turns itself off
it sounds like your tv might have a loose connection inside it call a tv repair man and tell him you might have a loose connection that or your tv is getting overused and probably burnt out
Dec 21, 2011 | LG DU-62SY20D 62" Rear Projection HDTV
I have a Harmon Kardon HK3490 receiver which has an input for a powered subwoofer. Next to the subwoofer output is a "link switch" which turns on the subwoofer when I turn on the stereo. What...
Connect the Subwoofer Trigger Output for each subwoofer to thecorresponding trigger input on its amplifier. This enables the subwoofer toturn on or off together with the HK 3490. To further conserve energy,when the trigger connection is made, turn the Subwoofer Link Switch onto turn the subwoofer off when the corresponding pair of main speakersare not being used, such as during muting, when headphones are beingused, or when the main speakers are turned off using the Speaker 1/2 switch
Apr 05, 2011 | Denon AVR-687
Chnaged the color wheel and lamp. stanby/temp and
YOU MAY STILL HAVE A BAD BALLAST OR POWER SUPPLY BOARD.Samsung recommends replacing the ballast and power supply board at the same time.
Jun 04, 2010 | Samsung HLP6163W 61" Rear Projection...
Bush lcd 37 inch tv keeps going to stanby
my bush lcd tv keeps staying in standby mode and wont go on if it does go on its only for a minute or two....
Help please
Mar 04, 2009 | Televison & Video
No Sound for Velodyne VLF-1012
Sounds like your amp is damaged.
Jan 29, 2009 | Velodyne VLF-1012 Subwoofer
Can't turn on from Stanby mode
I would assume the power board has a problem. A tech could possibly repair it without replacing the whole board.
Nov 13, 2008 | Pioneer PDP-5070HD 50 in. Plasma...
New Sharp Aquos LC37X20E. After 30 mins turns itself off to standby and comes back on after 2-5mins (even though the automatic return to stanby has been set to "disable"). Eventually after...
According to Sharp it is a software problem. Engineer came, installed software update ,10 minute job.....TV worked fine for 1/2 day unfortunately: Then images turned black and white in all channels TV turned itself off, and stanby and OPC buttons started flashing. When TV came back on its own 10 mins later , screen had 2 large square staines superimposed in image (as if it was a burnt screen)...Engineer will be back next week...all quite sad really for a new TV.....will keep u posted
Jul 03, 2008 | Sharp Televison & Video
59 people viewed this question
 Grubhead
Grubhead
