Question about Refrigerators
I have a 2002 frigidare frost free commerical up-right freezer and cannot get the compressor to come on. The compressor is a Embraco FGU 115-127V 60 HZ 1 PH
  • 552 Answers
Here is a link to trouble shooting answers.
Could be a bad start relay, overload, dirty condensor coils, condenser fan motor is not running.
If the link does not work then copy and paste.
http://www.applianceaid.com/refrigerator.html#clicking
Posted on Apr 29, 2008
    Genius:
  • 3,587 Answers
Hmmm..did you check the power and breaker first, by chance? light inside working?
Need to identify the prongs on my compressor. embraco egy90hlp wiring diagram
PDF]General Index - Embraco
www.embraco.com/DesktopModules/.../Arquivos/MP01EG.pdf
EmbracoApr 7, 2011 - Figure 6b Series EM - Compressor Model Identification Code . ....Compressor Wiring Diagram T Series (electrical component with terminal ...
Embraco PW 5.5A compressor - pins layout? - Refrigeration Engineers
www.refrigeration-engineer.com > ... > Domestic
Sep 4, 2008 - 4 posts - ‎1 author
My fridge-freezer quit working tonight - it's probably over ten years ... It's an EmbracoPW 5.5A, and the pins form an upside-down triangle, ... So, I want to try hard-wiring it but I'm struggling to identify the compressor terminals.
Identifying Compressor Terminals: Start, Run, and Main ...
fixitnow.com/wp/.../identifying-compressor-terminals-start-run-and-main...
Sep 9, 2010 - Let's say you're gonna do some tests on your refrigerator compressor to see if it's okay. Or, you need to figure out how to wire up a generic ...
Refrigerator compressor electrical question - AllisChalm
Jan 18, 2016 | Refrigerators
WRS6R3EW8 Refrigerator and freezer not cooling. Evaporator coil 60 deg. only. Compressor, evaporator fan and condenser fan running. Some frost on the tubing coming from condenser at the evaporator. ...
Where is it frosting, condenser or evaporator? If you mean frosting on evaporator line to compressor, probably iced up evaporator. If you mean frosting after condenser by capillary, unit short of gas/ blocked.
Apr 27, 2012 | Refrigerators
Frigidare Model No. FFU1464DW2 is leaking water on ground floor, can you tell me where to find the drain pan and what is causing this? Many thanks.
Most likely it is leaking because the drain in the back of the freezer is clogged. The most likely source of excessive water drainage is a bad door seal which causes frost to build up.
Nov 19, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Won't freeze
Is the compressor running the whole time? If so may have a problem with a refridgerant leak....check the compressor in the rear of unit, feel if its hot....may be as simple as a relay.
Jun 17, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer Compressor Motor turns on and right back off
please check the following list,
1) check wheather the service wire is in good condition or not.
2) thermostart might have been off.
3) turn the refrigerator backword and see if is there any wire is disconnected/cut.
4) try changing the plug of the refrigerator.
if your problem is not fixed than please contact the service engineer. i'm sure that your stater had been blown.................. have a nice day:-)
May 14, 2009 | Frigidaire Freezers
Freezer compressor runs steady & getting -30F
You probably have a defective thermostat or sensor for reading the temperature.
Mar 23, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer alarm is going off and water is coming out below our frost free freezer
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Dec 23, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire model # FRS26ZNHB2 side by side not cooling
T
From your description, you have a bad evaporator fan motor. The part number for a replacement motor is #5304445861.This is not a direct replacement but is more reliable.Remove everything in the freezer, take off the back panels and you will see the fan.
If there is a large frost buildup on the coils and the fan is turning you have a defrost problem. If that is the case, please call me at 334-347-0000 and I will walk you through it.
Jan 14, 2008 | Refrigerators
Refrigerators Logo
179 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
