FixYa.com
Tags:
Electric Kettles
Generic problem for all Electric Kettles
Kettle lights but doesn't boil
posted by jayney8 on Apr 29, 2008
My kettle lights up but has suddenly stopped boiling, what could be the problem?
Jayne
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 29, 2008
Not Rated (0)
jerryg50
Rank:Wiz Wiz
Rating: 84%, 523 votes
Most likely the thermo fuse is blown.
You have to take the kettle apart and see the spec for the thermo fuse. You can get these at most any electronics parts supplier for appliances.
To change the thermo fuse you will need the proper crimp type connectors and the crimp tool. This is not able to be soldered. It runs too hot, and soldering in a circuit close to a heating element is not able to be used.
Before changing the thermo fuse, you can test it with an ohm meter. It should typicaly read about 0.1 to 0.2 ohms. The heating element resistance should typicaly read about 8 to 12 ohms.
If the heating element reads below 6 to 7 ohms on a well calibrated ohm meter, or above 15 ohms, it is defective.
If the thermo fuse is blown, the kettle may have been left running when boiled out and over heated, or there is a short in the heating element.
If you feel that you are not comfortable to do this type of repair, it would be best to give the kettle out to an appliance service centre to have it serviced.
When you change the thermo fuse, and if it blows again the heating element is probably damaged. It must be replaced if possible, or if worth the cost.
On the other hand, if the kettle is more than a few years old and you don't want to go to all this trouble, you may want to consider to simply get a new one.
Jerry G.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: Panasonic NC-EH40PC Electric Kettle Panasonic NC-EM22P Electric Kettle Panasonic NC-EM40P Cordless Electric Kettle Black & Decker JKC450 Cordless Electric Kettle Cuisinart BA-165A Electric Kettle Dualit 72102 / 72100 Cordless Electric Kettle Electrolux EL6001W Electric Kettle
Can you Help with these Electric Kettles problems?
Le Creuset Kone Electric Kettle
My oval Le Creuset dutch
My oval Le Creuset dutch oven... Answer This...
Breville SK500XL Stainless Steel Cordless...
Breville steel ketell dose not
Breville steel ketell dose not... Answer This...
Electric Kettles
Pressure cooker probe
I need a probe for an Ultrex... Answer This...
Breville SK500-XL Stainless Steel Cordless...
cannot put the filter back
I descaled the kettle and I... Answer This...
Bravetti EK119H Electric Kettle
filter
I would like to find the screen... Answer This...
Repair Service
Find Electric Kettle Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
