HOW DO i CHANGE THE CARTRIDGES IN MY HPDESKJET3940SERIES
    Problem Solver:
  • 7 Answers
Here is a link to HP's website that has step-by-step instructions for the 3000 series of DeskJet printers:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bud09324&lc=en&cc=us&dlc=en&product=445449&lang=en
Posted on Apr 29, 2008
How to change all the ink cartridges at the same time because I was unable to remove some ink cartridges. The whole cartridges cannot be fully exposed.
Here are instructions on how to change the printer cartridges in an Epson Stylus. First open the printer cover. Look for the button with the picture of the ink drop on it. Press the button but do not hold it down for more then ten seconds. At fifteen seconds the align print cartridge function comes on and this will interfere with changing your cartridges. When you push the button with the picture of the ink drop on it, it will make the machine line up the cartridges in an area that you can reach easily. Then just remove the one you wish to replace. Use these instructions each time you change the cartridges.
Oct 01, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Have a c1900 but no disk for utility management to change toner cartridges, how do I get around this and change toner cartridges? Drivers are installed and printer in operation hence need to change...
You go through the menus :
Press Right arrow once,
Then down arrow 5 times (to Reset Menu)
The Down arrow 5 times to Change toner C (Cyan)
Then down arrow again to Change toner M (Magenta)
Then down arrow again to Change toner Y (Yellow)
Then down arrow again to Change toner k (Black)
Select your colour to change and press the right arrow. The engine durns, open the door and remove the cartridge
Jul 01, 2010 | Epson AcuLaser C1900 Printer
Lexmark x85 multifunctional, not recognize cartidrige color
The cartridges are only installed through the printer itself and there is no installation of cartridges through the Lexmark software. You should ensure the Lexmark X85 has the cartridges installed in stand-alone mode. To do so, please follow the steps given below:
1. Push the "Menu" button 10 times, until "Maintenance" appears.
2. Then hit "Select" and "Change Cartridges" should appear.
3. Hit "Select" again. It will prompt you to open the lid and change the cartridges. Please do so.
4. When the lid is closed, the display will ask you if new or old cartridges were installed. If new, it may ask you to align the cartridges and you should do this too.
If it is not noticing a change, remove and reinsert the cartridges about 3 times in a row to re-establish pin connections. If this still presents you with a "Change Cartridge" or "Low Ink Level" message or something similar, try a different cartridge.
Oct 17, 2009 | Lexmark X85 All-In-One InkJet Printer
HPofficejetpro L7580 doesnt recognize cartridges have been replac
hELLO THERE
there should be a section there for the maintenance of the cartridges and change cartridges make sure that you use this whenever you change out a cartridge cause if you use this when you change out the cartridge the printer will always show low on ink also you can reger to your users guide for further instructions on how to do this ok? hopethat this has been very helpfull dont forget to rate my solution
best regards mike
(USN) retired
Aug 05, 2009 | HP Deskjet 6940 InkJet Printer
Tonner exhasted and cartriges does not supportes
yes you change your printer cartridge . Your printer toner chip is disable. You buy a new toner
Jul 20, 2009 | Samsung ML-2240 Laser Printer
New cartridges don't work.
Most likely the printer needs to be sent for repair. Talk to HP and get them to fix it and take your cartridges and bills with you as they have to fix this.
Nov 18, 2008 | HP Officejet Pro L7680 All-In-One Printer
Changing ink for X1290
The printer needs to be on in order to change the cartridges. When you open the lid the cartridges should move into view.
Jan 15, 2008 | Lexmark X1270 All-In-One InkJet Printer
339 people viewed this question
jasbo
jasbo
