I have a Smasung CP150 printer. My printed material is coming through with streaks running through it ..full length. I have tried using laser printer cleaning sheets but to no avail. What is the problem?
  • 552 Answers
Go here for the Samsung download center.
They have a suport data base.
Posted on Apr 29, 2008
Transfer Belt Leaving Color Streaks on Pages
Try replacing color toner of the same color that are the lines.If the void was in the same place all of the time then I would say use a Q tip dipped in 90 proof alcohol and clean laser.
Apr 21, 2014 | Brother BU300CL Transfer Belt, 50,000...
Streaks on printed page full length even after installing new cartridge
Check the glass (the one the paper rests on). The underside of the glass that is. This is what the light 'sees', so, it will print this!
Jun 03, 2009 | Konica Minolta PagePro 1350W Laser Printer
i took out my drum and cleaned it with alcohol and then wiped down the inside of the printer anywhere the drum touches with a towel soaked with alcohol and the did about 40 prints and it fixed my pagepro (with each of these 40 prints the the quality got better)
May 15, 2009 | Konica Minolta PagePro 1350W Laser Printer
Right Side Printer Streaks full length of page
Hello sir; Make a demo page print out if still have same line coming out, replace the cartridge.
May 07, 2009 | Konica Minolta PagePro 1350W Laser Printer
Faded-out streak
check your ink levels. if its the ink that came with the printer it is probable running out of ink. they do not give a full cartridge with printers, only about 3rd full. also try cleaning the heads. and try changing your printer settings/prefrences to less ink, more drytime see if that helps.
Apr 26, 2009 | HP LaserJet 1018 Printer
Color prints have two strips of toner that will rub off.
Fixed the problem with the advice of one of your members!
Thanks
Jan 30, 2009 | Konica Minolta magicolor 2430 DL Laser...
2 Missing ink black streaks
Check the dev unit for missing lines. Also clean the laser glass with the supplied cleaner pad - though if the problem were caused by toner on the lens, there would be gaps in ALL colours.
Check the dev units first. You can also do a stop test whilst a full colour test image is half way through printing and see if the lines are missing off the image on the PCU as well.
May 20, 2008 | Epson Aculaser C1100 Printer
Minolta 2300DL Printer - black streaks
Hey Chuck, Any chance you can post a scan of one of the faulty pages ? This will make it easier to assess the fault. Print off about 10 pages of a page that is affected by the lines. Look at each page and see if you can detect a recurring pattern over any of the pages. If there is a pattern, chances are it is probably the PCU that is marked.
May 20, 2007 | Minolta magicolor 2300W Laser Printer
you will have to check the Minolta web tech support team for this one.
May 20, 2007 | Minolta QMS 2200DL Laser Printer
Without actually seeing a print sample or the machine, my bet would be on the black print cartridge. Even though it reads a an acceptable level of toner, the cartridge itself sounds like it has developed a proble. 1. It's the most obvious 2. It't the cheapest place to start. If it does not correct the problem, you can still use it later. 3. It's the problem in about 80% of these types of cases. 4. I know it should be fine, but if things didn't go wrong, I wouldn't have a job! Let me know. If not we'll investigate further. Ed
46 people viewed this question
k24674
jasbo
jasbo
