Question about Durabrand 5.1 Surround Sound Computer Speakers
Durabrand 80 Watts suroundsound
Well it worked well til yesterday, the fuse looks like I need to replace it, I did and still doesn't work, what's wrong with it, please??? Thanks  Florence
  • Anonymous Jul 27, 2008
    System will not power on
  • BIG FRED 08 Nov 13, 2008
    my system was working smoothly and all of a sudden is shuts off and never came back on
  • 12,061 Answers
It's either the Output IC's or the Power Supply Unit.. PSU.. But unfortunately it sounds like it has gone flakey..
Posted on Jul 29, 2008
Chevy 2001 Cavalier won't start
Trace the power source from fuse to relay etc and make sure pump is working. if all checks out then check pump working and for preasue at engine. you may have a dammaged fuel line from the tank which would also cause the same problem
Nov 27, 2012 | 2001 Chevrolet Cavalier
I need a fuses for my durabrand home theater system and model is ht-3916. i went to radio shack and purchase a fuse 1.6 amp volt fuses and it still don't work can you please help me thank you
Do you mean it blew them again or that it didn't work and the fuse is still intact?
If it blew it again the problem is not the fuses. Instead what you have is a semi-conductor device that has developed a short and that is blowing the fuse. Check any devices in the power supply section, look for signs of damage or heat and also any devices on the heat-sink.
If the fuse did not go and it still doesn't work check the power supply only or the on-off switch.
May 24, 2011 | Durabrand HT-3915 System
When I turn microwave on it blows 60 amp fuse
60 amps times12 volts = 720 watts times 80% effic of conv. = 576 watts available for microwave...
You must have a very tiny microwave as most require at least 1000 watts input power. That might have something to do with blowing the fuse. Since the microwave has a very reactive inout, you need a goodly safety margin above the rated watts input.
Jan 10, 2010 | Cobra Electronics - Others
Volume wont go past 50
this sytem is unable to go past 50 and because its only 80 watts it wont get louder.
80 watts is divided by all the speakers
so a 5.1 system gives 20 watts to the woofer and 15 watts to each of the other 4 speakers.
plus its in rms (root means square)
which means you loose some wattage in fricton so take another 25 to 50 % of the wattage.
so all this said you get what you pay for.
Apr 21, 2009 | Durabrand 5.1 Surround Sound Computer...
Durabrand ht-3917
where the fuse is: you don't need a screw driver, use your finger tip and push inward til you feel in push in and turn counter clock wise and poof it comes out....by chance when you take it out, looks at the chrome ends and Notice! # of amps...and how many Watts if you don't know this you'll be in my situation when try to find a replacement. but could you send me what both those are to my email?...thanks....watch_me_suffocate@yahoo.com
Feb 05, 2009 | Durabrand HT-3915 System
Portable dvd player durabrand model pdv 705
Those can be very fragile to remove or install. Sometimes all thats needed is the transformer board. Check for proper power and possible blown fuse. I may have the parts you need.
Nov 18, 2008 | Durabrand PDV-705 Portable DVD Player
Durabrand Car CD player
Sounds like you may have shorted the ignition lead, normally red). Also some radio manufacturers use a cheap fuse holder on thier radio harness so check the fuse holder and the fuse. Then check the radio fuse in the fuse block of the car. Finally check the wire harness where it plugs into the radio (if applicable) a wire may have pulled out.
Make sure all connections you made are insulated.
Jul 02, 2008 | Durabrand Car CD Player and AM/FM...
INSTRUCTION BOOKLET
look it up on the internet try that
Mar 25, 2008 | Microwave Ovens
Durabrand 5.1 Surround Sound Computer Speakers Logo
60 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Jonathon summesfield
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
