Panasonic error code fg1? wHAT IS THIS IS IT FIXABLE
  • 2 more comments
  • Anonymous Jan 13, 2009
    Yeah mine is doing the same thing, what's up with it? While watching TV, you hear almost a loud static noise once and then the sound cuts out. Then shortly after, FG1 is illuminated and the system shuts off.
  • 0zombie0 Jan 31, 2009
    hi!
    mine too!!
    it say FG1 and i don´t know what is it!!
    i can´t start up this thing!
    someone!!
    WTF is this!!!??
  • Mdaniels657 May 03, 2009
    Im having the same problem for months. Help urgently needed. FG1 error
  • Anonymous May 22, 2009
    i have the exact same problem can someone help me out when you've solved this problem its really stressing me out.
    Thanks
Check your power source, low voltage automatically shuts down unit and code pops. Check your main speaker speaker connections, it is always the culprit.
Posted on Feb 01, 2011
I just starting having the same problem this morning- think it's saying F61 and acorrding to the manual you should check and correct the speaker cable connections- and if that doesn't work call the dealer
Posted on Aug 31, 2009
If you have an error code of 021 in panasonic Fax machine.
checkout rare side paper pocket tray for adjustment.
to adjust it open rear side screws and then adjust it then rescrew your problem become solve.
good luck.
sohail Akram
0334-5332743
Posted on Sep 02, 2009
Panasonic home theather does not read DVD and display a U703 code
Panasonic display motor Home Theater Systems Questions ...
www.fixya.com > Forum > Tags > display motor > Home Theater Systems
Panasonic home theater systems display motor related questions and answers. Ask your ... ...getting a DVD H02 code it wont play cd's or dvd it will display the code and say stop. Is this fixable or should ... ...display a U703 code. Does I need to ...
Panasonic euromax new codes Home Theater Systems ...
www.fixya.com > ... > euromax new codes > Home Theater Systems
My Panasonic home theather does not read DVD and display a U703 code. Does I need to bring the equipment to a repair center or is better to get a new one?
Panasonic Home Theater System System Dvd u703 ... - Fixya
Dec 17, 2015 | Panasonic Sa-ht740 5.1 Channel Home...
My panasonic 50 inch plasma TV has 11 blinks . Is it fixable?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Type in the brand name and type of your device; here it is "Panasonic Plasma TV", in the search box [at the top right] of the display window. It will make surf easy.
Jun 16, 2015 | Panasonic Televison & Video
How do i fix an error code f61 for sa ak40 panasonic stereo
There is most likely a short in the amp that needs to be repaired.
Mar 13, 2013 | Audio Players & Recorders
Fault code fg1
If it's a panasonic the number are f61 and means the audio amplifier's IC's are damaged and need to be replaced
Feb 02, 2010 | Audio Players & Recorders
Hometheater system doesn't power up
A Panasonic? Most likely it will need an output ic or a voltage ic. It could be just a stuck fan (rare). F61 is a voltage error code.
Oct 21, 2009 | Audio Players & Recorders
Pana sonic home theater system Ho2 code
the problem be in the spindle motor drive circuit so you can solve it
Dec 24, 2008 | Panasonic Home Theater System System
Error message E7
Ok thsi is fixable E7 is an Automatic Document feeder or finisher problem. There should be another 2 other numbers flashing after the E7 to tell you where in these options the fault is. Hope this helps
Aug 17, 2007 | Panasonic FP-7735 Black and White Copier
1,572 people viewed this question
 Grubhead
Grubhead
