Ive got a 2wire 802.11g wireless adapter connected to pc but have no software or drivers were can i get them from im with bt yahoo broadband
  • 552 Answers
Go here
Or copy and paste into your browser window.
http://www.2wire.com/support
Posted on Apr 29, 2008
2Wire Help USB VISTA 64BIT
check for compatibility. The 2wire wireless adapter might not be compatible with your vista 64 bit
Sep 11, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
Wireless light not on
Wireless should be enabled, should have an SSID name and encryption setting. If this is still a BT connection, just call and they will dial in to it and check. Could be faulty, of course.
Aug 12, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire 802.11 usb without 2wire gateway
http://support.2wire.com/index.php?page=download click on the adapter link for the driver and instructions. If you dont see the picture of your adapter, then click on the legacy link on the adapter page. After you install the software just use the icon on the lower right to connect to your wireless network.
Jul 11, 2009 | 2wire Computers & Internet
Want guests to be able to use our AT&T U-Verse broadband network.
Try checking your wireless security settings to make sure you are using the correct wireless key (password).
Apr 13, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Problem with 2wire adaptor connecting to Avenue Broadband
Yes, The DSL connection and Broadband connection are different with each other.
You'll needing to reconfigure the router as Dynamic and clone the MAC address so that it will recognize to the network.
- Try resetting the router and reconfigure the settings of your router.
Mar 05, 2009 | 2wire HomePortal 100 Network Adapter
I need help installing my 2wire wireless adapter card.
I used this one:
Introduction
This document describes the procedure to install driver for the 2Wire Wireless USB Adapter under Microsoft Windows, and to run a wireless configuration program to configure your 2Wire Wireless USB Adapter to work with a 2Wire HomePortal or OfficePortal wireless gateway. These drivers work under Microsoft Windows 98SE, ME, 2000, and XP.
STEP 1 - Driver Installation
1. Make sure your 2Wire Wireless USB Adapter has not been connected to your computer USB port.
2. Double-click on the file to run WinZip Self-Extractor. The driver installation files will be placed in your hard disk in the C:\TWWUSB_TEMP directory
3. Connect your 2Wire Wireless USB Adapter to an available USB port in your computer. Windows Found New Hardware Wizard will startup.
4. Select the option to search for driver in specific location. Specify C:\TWWGUSB_TEMP as the location of driver.
5. Follow on-screen instruction to finish driver installation.
STEP 2 - Wireless Configuration
1. Run the program WirelessCfg.exe in the directory C:\TWWGUSB_TEMP. You can do so by clicking on the Windows Start button and select Run. The Windows Start button is typically at the lower left corner of the screen. Type in C:\TWWGUSB_TEMP\WirelessCfg.exe to launch the program.
2. Follow on-screen instruction to configure your wireless setting. Enter the serial number and encryption key as they are printed on the bottom of your 2Wire wireless gateway.
Sep 28, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
My usb adapter (2wire 802.11g usb wireless adpter) is having problems.
you cant change the wep key on the upstairs pc unless you change it on the 2wire 1st. the pc wep key has to match whatever the 2wire has it set to. go to the 2wire router settings throught the downstairs pc that is working to be able to see what the wep key is set to, then when you get the key or set a new one enter that key into the upstairs pc.
Jan 08, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
2wire wireless adaptors
I have installed 2 2wire adapters with no problem. When using config software utility, don't select gateway (if using only adapter), then continue until sets up. No serial # required unless using a gateway, which is not needed to connect to wireless.
Oct 15, 2007 | 2wire (1000-000005-002) 802.11g/b Wireless...
2wire router and usb adapter
first u need to connect a pc through wired on the w/l router and go to w/l part and configuge it
Oct 05, 2007 | 2wire (1000-400108-001) Router
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
