FixYa.com
Tags:
Bosch WFMC 3200 Front Load Washer
Rubber gasket Bello!
posted by Cherylnsal on Apr 29, 2008
What is the trick to installing the back (inner) steel ring around the gasket. I am attempting to put the gasket and the retaining ring on at the same time and the retaining ring keeps slipping off the gasket seat.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 04, 2008
Not Rated (0)
Coldcut
Rank:Wiz Wiz
Rating: 84%, 480 votes
it is very hard to get the ring on front load washers,
it is much easier to remove the top. bottom and the front control panel
then the door and support panel.
now you have access.
some times you have to remove the counter weight in some models before putting on the ring.
if you can do it without removing these items you are very very good.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Washing Machines problems?
exxcel 7 washing machine
how do I turn off the end of... Answer This...
Display does not light up.
Washer seems to work fine...... Answer This...
bosch fabric softener does...
Bosch front load WFMK6400UC... Answer This...
Bosch WFCM 3200 Front load...
I have a 2004 model I bought in... Answer This...
the water heater was cycling
the water heater was cycling on... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
