Question about Kitchen Ranges
THE PROBE ON MY GE OVEN ( J2S968 )NO LONGER WORKES PROPERLY. IT IS 2 1/2 YEARS OLD. THE PROBE WORKED PERFECTLY THE FIRST 2 YRS. NOW IF WE WENT BY THE PROBE READING THE MEAT WOULD BE WAY OVERCOOKED. WHAT ARE THE CHANCES THAT IT JUST A PROBLEM WITH THE PROBE WIRE ITSELF ? SHOULD I GET A NEW PROBE WIRE TO SEE IF THAT FIXES THE PROBLEM ?
  • geeboy2 Nov 27, 2008
    SImilar problem...sometimes the probe works and sometimes not...meaning you insert the probe into the jack and the oven doesn't seem to sense that it's there...I think the problem is the probe itself...the probe cable is too short and often the cable is pulled sharply against the jack (like when you try to slide the rack forward when the probe's still attached), probably the wires inside have become frayed.
    Genius:
  • 1,073 Answers
Replace the probe
Posted on Apr 29, 2008
M y dual fuel GE oven has no display showing it just went blank, but when you open the oven door the light goes on
I had the same problem as devlin50 with my GE duel fuel 918 model.
If you trip the circuit breaker off and leave for one minute before switching the power back on then hopefully the panel will be flashing, worked for me. Worth trying as replacement panel is not cheap, about $220 here in Canada.
TonyM
Mar 15, 2011 | GE Profile J2S968 Dual Fuel (Electric and...
CGS980SEM1SS GE Cafe gas range which is 2 yrs 2 mths old. Oven shuts off after 5 mins, 10 mins, 20 mins...and at any temperature. All control panel functions cease to work, and most of the times the stove...
Hi
The issue can either be a bad electronic control/clock assembly or the oven temperature sensor (probe) has gone bad. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then 1120 ohms then it should be replaced however, if it reads between 1080-1120 ohm then check the control and door switch and replace the part that is bad. You can also check the wire harness from the control to the electronic board. Hope this helps...
Daniel
Feb 11, 2011 | GE Cafe CGS980S Kitchen Range
Our microwave worked perfectly yesterday, today when we went to start it, everything was working but it never heated anything up at all. It is 5 years old
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 28, 2010 | GE JVM1440 Microwave Oven
Oven will not ignite, it is approx. 8 yrs old. 2 years ago the ignitor was changed for a similar problem. Everything works on stove even the broiler. Very dissapointed in the GE profile since I have had...
Jim your ignitor has gone bad once again.
You can turn off the gas supply,remove the oven racks,remove the oven base pan,remove the flame spreader to access the ignitor.
Place a clamp on amp meter over one wire of the ignitor and turn the control on for bake. If the ignitor does not glow at all. It is bad. If it glows and reads 3 amps or less on the amp meter it is still bad.
A proper functioning ignitor will light and re-light the burner in 45 seconds or less.
Jan 01, 2010 | GE Ovens
I have a GE self-cleaning radiant range about 13 years old. The self-cleaning feature doesn't work anymore. The latch doorlight, even though set correctly to the right,keeps flashing on and off and the...
It could be a micro switch in the latch mechanism not communicating properly with the display circuit board, or it could be the circuit board itself. The switch might cost 20 or 30 dollars, but the board could be hundreds. Kinda costly if you ask me...
Mar 13, 2009 | GE Kitchen Ranges
GE JVM 1650BB does not heat...
My magnatron went out on my 2003 model ge replaced the part but I had to pay the labor.Mine had a ten year warranty on parts.
Oct 17, 2008 | GE JVM1650 1000 Watts Microwave Oven
No more heating, GE Profile Microwave JVM 1870CF02
I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
Aug 31, 2008 | GE JVM1850 1000 Watts Microwave Oven
Oven turns on by itself
only thing i could say here is replace the control or clock its real name is an eoc electronic oven control now the part is under a five year warrenty but you have to pay labor and use some one that is authorized for ge warrenty work check your owners manuel for second to five year warrenty and go to ge web site to locate servicer in your area http://www.geappliances.com/service_and_support/service/
Jun 04, 2008 | GE JKP20 Electric Single Oven
Takes much longer now to heat things
I think you have two separate problems.
Taking a long time to heat is almost always a failing magnetron.
The cover on the side is the waveguide cover. If your waveguide cover is burned or broken, it will need to be replaced.
It protects the waveguide and magnetron from grewase and food particles, which can cause arcing and damage.
Hopefully your oven is just under the one-year mark and GE will fix it free under warranty.
Otherwise, they will replace the magnetron at no part cost, but labor will be your responsibility.
GE Customer Service is at http://www.geappliances.com/service_and_support/contact/
We're happy to help and we appreciate your thoughtful rating of our answer.
May 10, 2008 | GE Advantium 120 Convection/Microwave Oven
Kitchen Ranges Logo
267 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
