Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman door opener
Just replace drive and worm gears and experiencing problem similar to bentomi and others...unit starts in one direction and reverses after 2 seconds until it hits the upper limit. Speed cup is set as far as it can go but problem persists. Any other suggestions?
  • 504 Answers
Did you align the chain or belt?? If not That would be the problem.
Look at the instructions that came with your gear kit. they have a detailed step by step proceedure.
If it's not the alignment it is probably a bad circuit board.
Hope this helps
Posted on Oct 05, 2010
I have a Craftsman 1/2 hp, mod # 139.53603. When I press the remote or the panel button there is a humming sound from the motor. I opened the panel on the back and did not see anything out of line, etc. ...
Is the trolley jammed against the bolt just in front of the motor? If so, loosen the chain until the tension is off the trolley and then run the motor until the door is closed. Now locate the up limit on the side of the motor unit and turn this control 2 full turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Jan 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
Is there any adjustment for the gear drive sprocket that meshes with the worm drive? my gear is not engaging any more
If your drive gear is not meshing with the worm gear it is because it is worn out. You'll need to replace it post haste. The part number is 41A2817 and is available at Sears or any good door opener service company.
Dec 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door only opens 4 inches then reverses and stops
you need to replace gear when the door is fully closed. then do your tweaking.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need part 41A2817 drive/worm gear kit for Sears
as long as the door is less than ten years old, sears will stock the part you need. you can contact them through this link.
http://www.searspartsdirect.com/partsdirect/index.action?psid=58709328&sid=PSx20071217x00001a
Apr 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener - Gears need to be fixed
Unplug the unit and remove the cover, usually eight screws, if you see a lot of white dust in the cover check the nylon drive/worm gear, they will need to be replaced.
Apr 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage opener cannot close, just replaced gears.
If the unit has photo eyes that could be your problem. not reattching the 4 wireing harness from the limit assy. can cause a similar issue.
Dec 13, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Craftsman GDO Will not close
readjust the sensor controls on the side of the unit
Dec 28, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
97 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
