Question about Hotpoint 23 in. BFI62 Built-in Dishwasher
Overfill Hi Mark ,my Hotpoint BFI 62 at very first use ,takes water but in few minutes later water come out from floor and after that you can hear water drains out,Heavy Duty cycle light flashing rapidly,after some advice looked exactly source of water is from pipe connected to overflow system. That mean it is filling more than required,how it possible new Dishwasher never used before? Please help me to repair because we never try when I bought now is to late for company warranty. pareshuk@hotmail.co.uk
3 Suggested Answers
SOURCE:
Poohs
  • 4 Answers
SOURCE: BF162 Hotpoint intergrated dishwasher
When you switch it on can you still select the wash type ?
If you can, when you shut the door does it start the cycle normally by pumping out the sump, but then when the wash pump (the cause of the main noise during the cycle) would normally start it stops and beeps - opening the door then shows the flashing error code ?
If your symptoms are the same as above or similar, suspect the heater is stuffed. My BFI62 did the above and it turned out to be a faulty (open circuit) heater. As I had no knowledge of dishwashers at the time, I called in a repair guy. As soon as he saw the fault code he suspected the heater - seems a batch of heaters (from the USA) had proved very unreliable (apparently Hotpoint got compensation from the manufacturers because of the number of problems it caused them). The replacement was made in Germany and the repair guy said he'd not known one of those to go faulty !
The repair guy diagnosed the heater open circuit from the control panel inside the door without even removing the dishwasher from it's location. Unfortunately, I didn't have a chance to note which wires ran off the board to the heater. Changing the heater needed it out and on it's side (be prepared for quite a lot of water on the floor).
Finally, when he'd fitted the new heater, it took him two goes to get the pipes either side of it to seal properly - quite common apparently and the source of even more water on the floor !
Hope this helps.
Posted on Jan 01, 2008
SOURCE: function buttons do not work on off button does
I have expreienced the same problem and carried out a hard re-set by holding down the on/off switch whilst pressing the program button. It's now working - but not sure for how long!
Posted on Feb 28, 2009
Water leaks underneath on the floor of my Hotpoint refrigerator Model # ctx21d.
If you have an auto-defrost refrigerator, the defrost water collects in a plastic tray at the bottom where it eventually evaporates. Your tray could be overfilling, damaged, or misaligned with the drain tube
Mar 18, 2013 | Refrigerators
HOTPOINT DISHWASHER BFI 620 ERROR CODE LED FLASHING 1 & 3
Check the end of your drain hose for the clog.
Feb 17, 2013 | Dishwashers
Hotpoint Aqualtis throws water out of soap draw during rinse. Have checked pressure switch & tubing. How do you get to the pressure chamber to check for blockage? Could it be anything else?
I would remove the dispenser drawer by pressing on the release button, then clean out under the drawer. The reason I say this is I have had a few do this and I found a rinse agent clogging unit it cause the water during rinse to dispense forward and leak on the floor. It not difficult to clean out, this can take up to 10 minutes or so to fix with no parts needed.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 31, 2011 | Hotpoint Washing Machines
Hi My BFI 680 trips the electricity at the mains just as you put it on. Have cleaned the filters. Any ideas ?
could a internal fault in m/c[shorted wires] water,faulty on /of switch,recheck wiring to m/c
Dec 31, 2009 | Hotpoint 23 in. BFI68 Built-in Dishwasher
Water all in laundry room floor
Did the washer overfill or do did it leak the water out from somewhere? Typically, if the washer is overfilling it is caused by a faulty water level switch. This is a diaphragm like device with a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level rises, pressure increases on the air in the tube and when it reaches a certain point, it activates the switch to turn off the water and signals the timer to agitate. Look for any obstructions in the tube and the switch can be tested for continuity with a multimeter. No continuity means the switch is defective. Hope this helped and best wishes.
Aug 02, 2009 | Kenmore 98702 Stacked Washer/Dryer
How do you read the oil level correctly on dipstick to 1995 Saab 900S?
All dipsticks have an upper and lower mark ..the top mark is the full mark and the lower mark is the add oil mark. Check it with the engine off on level ground.  Also after the motor running at take a few minutes for the oil to return to the oil pan to get an accurate reading.
Do not overfill.
Mar 23, 2009 | 1995 Saab 900
Washing machine overfilling
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your washing machine overfilling.
please give us more information .
What is the manufacturer and model number of your problem washer?
Thank you
Sep 29, 2008 | Washing Machines
Dishwasher does not heat up
the heater t.o.c will be blown it may be resetable access by removing the side panel if the stat is resetable it will have a red button on the top simply press till you hear a click good luck
Jul 21, 2007 | Hotpoint 23 in. BFI68 Built-in Dishwasher
Hotpoint 23 in. BFI62 Built-in Dishwasher Logo
Top Hotpoint Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
