Question about Cameras
Ive broken the plastic slide lock on the battery door, anyone no were to get one ? cheers
  • barwench May 19, 2008
    My camera still works great and takes good pictures but my battery door that slides across the batteries broke. Now I use it with a piece of duct tape to hold everything in and I still have to use my thumb to add pressure. Is there someone out there that has a parts camera or avenue to purchase one at a reasonable price? The Polaroid official site wants $20.00 but I'm not sure I want to spend that much just for the door when the camera is now available to $75-$90.
  • spartyfan846 Dec 23, 2008
    I push the battery in and add a little piece of paper to make sure that it stays "connected". It still drains quickly as it must not have a solid connection.
I just bought one from Kodak, more expensive with the shipping than those available on ebay. No instructions however, so now I have no clue as to how to replace the cover...
Posted on Apr 30, 2008
Have a Genie garage door open. The wall control unit has a slide lock switch. When slide switch is place in lock position, you can still raise and lower door. What could be the problem?
The plastic slide-lock switch's tab on the inside of the switch body is likely broken. If the lockout function is important to you, order a new switch unit from a door service company such as Overhead Door. Installation is DIY-simple.
Nov 26, 2017 | Building Materials
1998 sienna driver side sliding door lock sticking
You can take off the interior panel and fix it there: https://www.youtube.com/watch?v=MkC2OiOiE_U
Mar 28, 2017 | 1998 Toyota Sienna
1997 Toyota Rav4 driver side interior door handle broken
Parts can be had from a junk yard...remove door panel and push up on the connecting rod to open...generally, a little piece of plastic slips off or breaks inside the door. It is attached to a certain part of the rod. Should be white or clear plastic...look for the broken bits when door panel is removed so you know what you need....cheers
Jan 24, 2018 | 1997 Toyota RAV4
2006 Dodge Caravan - ONE power door lock stopped working
i have replaced many sliding door lock actuators on these vehicles..dealer part..mostly on passenger side sliding door..also possible you have a broken wire in door track harness..follow wiring from door into what looks like a plastic chain in door track at door opening
Apr 30, 2009 | 2006 Dodge Caravan
Broken exterior door handle,passenger sider ,sliding
Got this idea from mpvclub.com: Get some stainless or aluminum sheet metal screws, drill pilot hole into the handle and into the receiving part behind, then screw in the screw. Do on both sides of handle (get appropriate length screw.) When done, get some putty or hardener to fill in the screw slot, let dry, then sand smooth, then paint with body color. Result is great and inexpensive.
Jan 26, 2009 | 2004 Mazda MPV
NEFF H5470NOGB Microwave door latch fault
theres a small plastic hook inside the door which holds a tension spring this will have snapped off stopping the latch from entering the lock its actually quite easy to fix the inner plastic frame can be unclipped with a small flat blade screwdriver exposing the hook mechanism and the spring will be lying in the bottom of the door frame you can reconnect it to the metal inner frame it stretches the spring a little more but it will never snap again ive done this loads of times with no probs otherwise you will have to replace the outer door to reinstate the broken hook.
Oct 27, 2008 | Neff H5470 Microwave Oven
2005 Toyota Sienna Sliding Door Won't Open
Have 2005 Sienna and its Driver side door was not openning. Cheap dealer fixed it himself in front of me. After opening the doors plastic assembly while sitting inside with a screw driver. Then he bent the clip towards left where the metal wire is connected. If you guys want to see what he did i would record a video and upload for you guys. Let me know at xahid2000@yahoo.com
Jul 22, 2008 | 2005 Toyota Sienna
2033 kia sedona sliding outer door handle
take inside door pannel of,gently remove plastic sheet,and you will see door handle,un clipdoor lever and nuts,
Jul 12, 2008 | 2003 Kia Sedona
Battery door broken
You're making it harder than it has to be. Simply hold the camera in your left hand, and open the battery door so it is standing up. Look closely at the lower left corner of the batterry door. Notice the notch shape. The door plastic door is locked in place by the mating little "L" shape on the hinged door of your camera. Thats all that keeps it from sliding off when you put in batteries. Simply insert a small screwdriver or knife blade in that slot, twist it counterclockwise to push the battery door lock to the left, and slide the door off with no force at all. It's a snap.
Jan 15, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Cameras Logo
111 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
