I own a maxtor hard drive model 92041u4 and I need the jumper settings. It is a master
  • 52 Answers
Http://eshop.macsales.com/Tech/manuals/idehdsettings/Maxtor72.pdf
here is the manual for the jumper settings
Posted on Apr 29, 2008
Maxtor hard drive settings for a 53073H4
Before doing anything, the user should completely shut down and unplug the computer to prevent electrocution or computer damage. Remove the computer's side panel so that the hard drive is displayed in order to find the jumpers on the IDE drive. Disconnect the power and IDE cables from the hard drive to access the drive better. The hard drive's jumpers are the small, black pegs on the back of the drive. These pegs fit over small metal conductors and assign the IDE drive's role. The user can remove the jumpers by prying them off of their current conductors with his/her fingernails or a small screwdriver. The jumpers can then be relocated to other conductors in order to assign a role to the IDE drive. The user should be very careful while handling the Maxtor jumpers as they are fragile and very important.maxtor-jumper-settings.jpegEach IDE drive model is different but most have three basic settings: Cable Select, Master, and Slave. Each setting is described below.
Cable Select
Cable Select is a Maxtor jumper setting that is the default for virtually all IDE drives. Cable Select allows an IDE drive to naturally become either a Master or Slave depending on the cable used. Cable Select is a neutral setting and is also often used when a user only has one IDE device installed or when a device is neither a Master or a Slave, such as a Floppy Disk drive.
hope this helps
Jun 22, 2012 | Maxtor Hard Drive
What settings in the bios with maxtor as slve and quantom fireball as master
There are no settings in the BIOS for setting up master ans slave drives.
The hard drives have jumpers for configuring master and Slave drives.
If your hard drives are IDE/PATA hard drives and you intend to install these drives on the same IDE cable then you can set the jumper on Quantum drive as Master and the Maxtor on Slave.
I suggest that you install the Quantum as master on the 1st IDE cable and the Maxtor as Master on the 2nd IDE cable for maximum data transfer rate between the two hard drived.
Any other devices that are connected to these IDE cables will need to be jumpered as Slave devices.
Mar 28, 2012 | Gateway Computers & Internet
I want to add another hard drive and need to know how to set the jumpers on my maxtor 90645d3 please help.ty
if you want to boot from this drive, please set the jumper to the master position.
if this drive is for additional storage, please set the jumper to slave. and make sure 1st hard drive is set to master.
if this is the only drive in the system, please set the jumper to single or remove the jumper.
there will be a chart telling you which pins are for which setting in the jumper area, which is between the data plug and the power plug on the back of your HDD.
main thing that will cause drives to not work is 2 jumpers on the same cable and they both are set to the same thng.. i.e. master/master or slave/slave. also, if one is set to single drive it will likely bypass the slave drive.
Jan 25, 2010 | Maxtor Hard Drive
Maxtor hard drive jumper setting for model 6v200e0
here is a poster of Maxtors jumper settings for each kind of drive.
Nov 12, 2009 | Computers & Internet
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
Jumper settings for a maxtor N256 master with slave
Select the maxtor HDD as master by setting the Jumper to the extreme left of the hdd; i.e. next to the data cable.
Remove all jumpers from the other HDD which you want to put as slave.
Sep 02, 2009 | Maxtor DiamondMax 80 (96147H6) 61.4 GB...
Maxtor slave jumper settings
Find the jumper settings for the maxtor harddrive on the following link. As per the model number you gave ,it seems like you have the maxtor diamond max drive.
http://www.tacktech.com/display.cfm?ttid=379
Thanks
proton
Nov 29, 2008 | Maxtor Hard Drive
Slave harddrive jumper settings
usualy its just one jumper if no jumper on maxtors becomes slave. jumper on 50 is master. if u use cable select.. on same ide another device must also be cable select.
if one is master other is slave on same ide.
Jul 15, 2008 | Maxtor Hard Drive
Need help on how to attach jumpers on Maxtor Hard Drive Model # 4D040H2
It is in my experience with hard drives used in external USB enclosures - the jumpers are not nessessery.
Jul 04, 2008 | Maxtor Hard Drive
Maxtor hard drive model 54098h8 where do I put jumper for main drive
on the model 54098h8 this is a IDE drive and was in service in the mid 2000 era. most drives warranty expired by 2003.
the jumper postion is for J50 which is MASTER with jumper ON and SLAVE OFF See photo below or look on this link
http://www.seagate.com/staticfiles/maxtor/en_us/documentation/manuals/d540x-4k_guide.pdf
All material contained herein Copyright © 1999 Maxtor Corporation.Contents and specifications subject to change ®
without notice.DiamondMax™, MaxBlast™ Plus and MaxFax™ are trademarks of Maxtor
this is a photo of the master from the PDF
May 07, 2008 | Maxtor Hard Drive
Computers & Internet Logo
458 people viewed this question
David Payne
David Payne
