Can't access internet
I have an HP laptop. It has the wireless bottom on the front that you slide back and forth to turn off or on. It is blue when on. My button no longer turns blue for on and I can not access internet. It says no wireless network available and then another thing said to plug in the adapter to the computer. I have not clue. Is this something that can be easily fixed. I was using it one minute and then 30 minutes later when I wanted to get back on that was it no blue and obviously no connection.
I can't remember the Model name at the moment. I think it is a HP duo core
  • john wasson
    john wasson May 11, 2010
    i had a very similar problem on my compaq presario (hp bought out compaq) and i end up having to call customer service and having them replace my wireless card and my mother board. hope this helps
If ur computer is old may be the battrey on mother board is dead thats why this is giving you this problem
Posted on Apr 29, 2008
How do I turn on wireless conection in a gateway acer laptop
There is usually a function key combination (Fn+F3) or a slide switch on the side.
Jul 26, 2014 | Gateway Computers & Internet
I'm having problem connecting to the wirless internet on dell lataqitude e5500. The wireless is on but im unable to connect to any wirlesss networks? Can this problem be solved?
If you are using a firewall disable it there is a wireless toggle switch on the side of your laptop. It slides back and forth to turn your wireless card on and off. It has a little wireless symbol next to it, and you should NOT see red. If you see red showing, it means that the wireless adapter is turned off. Slide the adapter to the ON position, and then try to repair your wireless connection. Hope this helps
Sep 01, 2011 | Dell Latitude E5500 Laptop
Hello, I have a HP Pavilion laptop but the HP WLAN is always disabled. How can I fix this problem?
All laptops have a user button or switch to turn the wireless access on or off. Look for a red light above the keyboard; touch it and it should turn blue (that will turn the access on again). Alternatively, you could have a switch in the front or along the sides to turn wireless access on or off. Hope this helps.
Oct 26, 2010 | HP (F2135A#AKY)
Cannot access the internet
I have looked at and reviewed your problem with your HP laptop DV6700Z and have the fallowing for you to aces.
First, if you are trying to access the internet via wireless, wait until you have established and wired connection.
If the blue light comes on in the front panel, the wireless is working, if not, you have a problem with the wireless modem.
Run a wire from your laptop to your modem and enter your my network, choose setup a internet connection.
Try to make a internet connection. Once you have established a connection, you can setup your wireless connection.
Hope this has helped you.
Sep 28, 2009 | HP Pavilion DV6700Z Notebook
I cant find the switch to turn on my wireless capability on my HP paviliondv71137
it should just automatically find a wireless signal. go into your network file and look around to see what it says. mine just found a signal didn't have to do anything. click on start menu you'll see network click there.
Jun 10, 2009 | Computers & Internet
Wireless access
There should be a switch on the very front and bottom of your computer that slides back and forth, enabling or disabling the wireless. If this is set in the on position, you can press FN (next to CTRL) and F5 and turn the wireless on or off from there as well.
Even if the physical switch is set to ON, the settings when pressing FN+F5 may be off.
Mar 22, 2009 | IBM ThinkPad T40 2373 Notebook
2 laptops - one connects to internet - other doesn't.
Theres a little slide on (or flip) switch to turn on your wireless. It can also be slide (or switch) off to turn off. Its usually located in the lower right front and sometimes its on the side depending on the model of your laptop. Theres usually a quick reference guide that comes with the laptop and that will show you where the USB ports are at, serial ports, AC jack, audio jack, CD Rom, and specifically where your wireless switch is located. There will also be a light ( blue or green indicating its on ) so once its on it can pick up wireless router signals, hence allows you internet access.
Jan 01, 2009 | Acer Aspire 5050 5430 Laptop
Wireless problem with laptop, HP DV9000
Follow the link below, read about this problem, and then call the special HP phone number. They are repairing these computers under a special enhanced warranty policy, even if the regular warranty is expired. Good luck!
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01087277#c01087277_identify
Dec 27, 2008 | HP Pavilion dv9000z Notebook
Wireless button
is the light blue at your front slide button L/H lower front - if it is orange your wifi is inactive - slide it to on. If it is selected on and light is still orange - check the device manger in control panell - if the network devices at indicated update the wifi drivers from the HP.COM website.
Jul 09, 2008 | HP nx9110 Notebook
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
