1993 Panasonic color TV (can't find model number on TV)picture is too dark and the regular adjustments do not get it bright enought. I see a small opening on the back of the set, is that an additonal adjustment control?
I'll give it a try, but just so everybody is on the same page, this is not a projection TV but a direct view.
There is one slot on the back of the set that looks something like a hole about the size of the end of a hat pin with a slanting line going about 40 degrees to the left then ending with another hole about half the size of the first one, so I guess there could be 2 adjustments in there. I just didn't want to futz with it in case it was something that could do something I might not be able to undo.
TIA 1993 Panasonic color TV (can't - moz-screenshot-2.jpgmoz-screenshot-3.jpg
Posted on May 02, 2008
  • 2,335 Answers
You can try to adjust the screen control a bit higher to get the picture to an acceptable viewing level.
At the back of the TV you will see the small opening, It should have 2 of them, one for the screen control and the other one should be focus. Adjust the screen control first and you might need to adjust the focus as well.
Hope this helps.
Posted on Apr 29, 2008
Color settings for an older panasonic tv
a model number would help to give an informed answer.
Dec 04, 2012 | Panasonic Televison & Video
Picture is too dark
Have you tried adjusting the brightness, contrast and color controls?
Jan 02, 2010 | Panasonic Televison & Video
TV is dark
you can fix this problem. remove your tv back cover, there is a part called Flyback. attaching to picture tube. it has two probs for adjesting focus and brightness.adjust your brightness porbe.
Aug 16, 2009 | Televison & Video
DARK AND COLOR RED
It is more than likely a convergence issue rather than a color issue.
Jul 19, 2009 | Panasonic PT-51HX41 51" Rear Projection...
I have a JVC 27'' AV-27530 TV that the picture is very dark
An aging FBT if it still can be adjust using screen adjustment on FBT that will be a small tweak.
But if you are inexperienced with this, asked someone who knows how to do it to fix it for you.
Apr 08, 2009 | JVC AV-27530 27" TV
TCL TV picture too dark
try turning the light sensor off
Oct 20, 2008 | JVC AV32F476 32" TV
Dark picture
do you get all three colors? red, blue and green?
Dec 16, 2007 | Panasonic PT-51G44 51" Rear Projection...
Panasonic ctp2780sf Picture very dark
check the ABL at the flyback and solder any bad connections there. U can increase the brightness at the flybacks buttom control .
Dec 29, 2006 | Panasonic CT-27SF25 27" TV
RCA F32649
i dont know this exact model, but i can advice you based on a slightly diffrent model. i hope the solution will be valid for your model as well: TV is digital controlled and have to be adjusted via service menu except the external focus and screen on back of (flyback) high voltage transformer. This is one you can try: Need plastic allen or plastic small flat blade screwdriver to fit these. Focus is top, bottom is the screen that set the overall brightness. Before adjusting, go in menu: press menu once, select picture quality, I think number 4, press 2 for "preset..", press 2 again to select normal. Back out by pressing zero repeatedly. It may ask you to save new settings, select yes. If screen is adjusted too bright, picture look lousy (washed out) the blacks will light up (becomes grey, or visible lines) this means you have actual fault that prevents you to get decent pix, that when it is time to take it in for repair.
Feb 11, 2006 | RCA F32649 32" TV
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
