Question about Lands Phones
Ive got a universal bluetooth headset h680 and i cant make voice calls with my phone how do i do a voice recognition
Depending on your phone I guess it could be other problems but I have a blackberry 8310 and have to take the battery out and just stick it right back in to reset it to get the voice option to work. It's a little bit of a hassle but works and I've heard others have had this same problem. See if that works.
Posted on Apr 29, 2008
Unable to make calls using voice commands
Try by reseting your Headset device following this steps.
How do reset the H19txt to factory default
You will need to re pair the Headset with the phone.
Jun 30, 2014 | Motorola Mobility H19txt Universal...
I have a previous cellphone using a bluetooth but suddenly my cellphone was broken . now i have a new cellphone again and how to connect a bluetooth.
Motorola H680 Wireless Earset specifications
here are the specs for your device, you can call your cust support for your phone provider or motorola tech support to learn how to use if you don't have and operators manual.
Jul 07, 2012 | Motorola Mobility H680 - Headset -...
How do I use voice dialing
Voice dialing with the Discovery 925 should be just as easy as pressing the "call control button" for a couple of seconds and it usually prompts your phone to ask for a command. However please keep in mind that the cell phone (and service) must be capable of voice dialing, also voice dialing and voice recognition on a cell phone are two totally different things. Sometimes those are misconstrued.
To view the Users Guide (Under Additional Information): Plantronics Discovery 925
Good Luck from Headsets Direct!
Jun 14, 2011 | Plantronics Discovery 925 Bluetooth...
Set up voice command and it calls the wrong person.
According to the user guide you tap the headset for voice recognition selection. However sometimes it may be the error of the phone not recognizing the name you want to call. Sometimes the names are similar in speech (Craig, Greg, Tim, Kim) you may want to change to last names or a combo of a name (Billybob). Check your phone recognition without the headset to see if it is the headset not making the name right. If the headset is still under warranty I would get a replacement.
Good luck from Headsets Direct!
Mar 27, 2011 | Plantronics M100 Bluetooth Headset
My phone is asking for a passkey to connect bluetooth.what is the passkey for the motorolla H680
For security reasons, most Bluetooth enabled devices require you to use a passkey.
Note: Motorola handsets and accessories will use the following default passkeys: 0000 or 1234.
Aug 10, 2010 | Motorola Mobility H680 - Headset -...
Pair my h680 to my razr m9c
When you turn your bluetooth on you should press and hold the button and it will flash several times then the light will stay on. On your phone under bluetooth devices select the " find devices" and it should pick it up within a few seconds.
Jun 07, 2009 | Motorola Mobility H680 - Headset -...
Problem w/ connecting h680 to EnV2
just get your bluetooth in pairing mode (steady blue light) then have your phone find the device then connect them when they ask you for the pass code its 0000 if your bluetooth is connected to a different phone you must disconnect it and if it doesnt work and you tried your best try turning the phone off then try it again sometimes this does the trick
Mar 29, 2009 | Motorola Mobility H680 - Headset -...
I have a LG KP500 (cookie) which I want to use with my Motorola bluetooth headset. I've paired the devices successfuly, and can use the headset to receive calls, but can't find a way to use the headset to...
Unfortunatley the LG KP500 (cookie) has no voice recognition services. When I first got it I did try to figure it out a few times but after I read the users manual theres nothing in there about voice recognition sevices so I came to the conclusion that it has'nt got that service.
Mar 19, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
How to make a voice call
Are you sure the phone is voice command capable? To set up on the phone you must follow commands to repeat several letters, numbers & words. If you have done that then push the button on the headset & you should hear "say a command".
Jan 25, 2009 | Motorola Mobility H680 - Headset -...
Lands Phones Logo
69 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
