Question about Canon imageCLASS D860 All-In-One Laser Printer
Torsion spring I have a imageclass d860 printer whose torsion spring fell off from the right door latch...can't figure out how to put it back on
  • catvet94 Sep 24, 2008
    I have the same problem - I have a new spring and cannot figure out where it goes. Thanks!
  • 3 Answers
1. Hit Additional Functions Key
2. Hit # key
3. Arrow to number 7, Printer and hit Set
4. Arrow to number 4, Printer Re-Set and hit Set.
5. Yes, re-set printer (hit minus key - back arrow).
6. Unplug the machine and plug it back in.
This just worked for me on a D860
Evenel
Posted on Jun 02, 2008
I did the clutch and now there is a shudder when pulling away and in between gear shifting. Please help
Did you put in a rebuilt clutch or a brand new one?
Shudder is usually weak clutch disc torsion springs.
Rebuilt discs may have weak torsion springs on the clutch disc while new clutch disc torsion springs should be "new" and should not cause clutch shudder.
One other cause can be broken or damaged motor mounts.
May 17, 2017 | Cars & Trucks
Torsion Bar on Cadillac dts 2006 fell off but isn't broke, how do I put it back on. Amy suggestions or links showing how to install?
Whatever fell off isn't a torsion bar - there isn't one. For help, describe the part better (a picture would help).
Dec 24, 2016 | 2006 Cadillac DTS
Fix broken garage door torsion spring
I would call a residential door company. Those springs are not something I would recommend the average homeowner to mess with. Sorry!
Jun 01, 2015 | Building Materials
Door well close but not open
This could be a broken torsion spring. See link below to see what a broken one looks like.
Replacing Broken Torsion Spring on Single Spring Garage Door
Oct 05, 2014 | Building Materials
Trunk lid torsion bar
If you have a local scrap yard, contact them as they remove parts all of the time and they can advise you of how to put them back.
May 10, 2014 | 1996 Chevrolet Cavalier
Torsion spring is broken for our liftmaster 2265R model garage door opener and i need a new one where do you buy one?
Here are instructions for replacing the spring. You can call any local garage door company and they will sell you the springs. I absolutely don't recommend this job for a DIY'er. It is dangerous.
http://ddmgaragedoors.com/diy-instructions/replace-garage-door-torsion-springs.php
Feb 23, 2011 | Sears Craftsman LiftMaster Chamberlain...
My Liftmaster Formula 1 garage door opener has started to shut unevenly, making one side of the closed door slightly higher than the other. This leaves a gap under the closed door on one side. The door...
my friend had the same problem and yes that is what we did. It took a wile to set it evenly. Wouldn't think it would take long but it did. We inadvertently set them to tight and door wouldn't close it would reverse on itself because of the added tension. In the end we did get it though.
Feb 04, 2010 | liftmaster Chamberlain Garage Door Opener...
What locks in the left and right torsion springs
the proper set up on thre bar which hols thr springs is plate lock handle part 107-3946 then the right hand torsion spring 108-0953,make sure the spring hooks over the plate lock, then left hand torsion spring then bar slides through left hand hole and lever release 40-1823-03 attaches to end of bar with a set screw
Sep 22, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Door openly opens 5-6 in, then stops.
If the door isn't unusually heavy when you open it manually then maybe an adjustment will help. On the back of the motor unit you will find the 'up force' control. Increase it 1/4 turn and try.
Jun 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Kitchenaid Microwave torsion spring replacement
I just replaced torsion spring 4452396 on my microwave. We heard a "pop" and then the door got heavy. here are a couple things I learned...THE HARD WAY!
We had the stainless steel front to the door and needed spring 4452396, not 4451008. The stainless steel door is heavier so therefore a stiffer spring. I'm not sure i could justify the 4x cost in the part...but that's just the way it is. It's a bit of a pain to repair the thing..so it's worth it to get the correct spring. You don't wan to be doing this every couple of of months!
You have to remove the front panel of the door to access the springs. there are 2 of them...they cross each other in an "x" pattern on the lower part of the door. We had to pull the unit out a bit to get the spring in the hole for correct position. No need to remove the door etc. If you need help with this...email me.
My mistake was when I was trying to figure out how to gain access to the springs I assumed you did from the inside of the door. I removed the two black things you see on the lower right/left of the door (screw on the bottom of them) then proceeded to remove the two recessed screws on the inside top corners of the door. Well next thing i know.....CRASH! the whole front of the door fell off and shattered! Come to find out those screws and brackets on the bottom hold the face of the door on. The glass is intergrated into the color panel of the door..so it's one piece! 150.00 later and a new piece of glass/panel i learned a hard lesson.
Let me know if you need help...it's fairly easy to do now that I look back on it. dave dlacki@gmail.com
May 14, 2008 | KitchenAid Architect Series KEMC308KSS...
Canon imageCLASS D860 All-In-One Laser Printer Logo
79 people viewed this question
old marine
old marine
