NEED A BACKGROUND FOR MY PAGE - Computers & Internet
    President:
  • 2,712 Answers
There are many websites that offer free backgrounds for websites, or at least that is what I understand from your query. Here are a few:
http://www.free-backgrounds.com/
http://www.aaabackgrounds.com/
http://www.grsites.com/textures/
http://www.allfreebackgrounds.com/
If this was not what you were looking for, please post back and I will assist you as best I can.
If you find that the solution/answer I provided led you to, or resulted in a fix, please take a moment to close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 29, 2008
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    rating under my solution.
    Should you have any further questions, please feel free to
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
Tip
How to change background image of Google home page ?
If you like to change background image of Google home page as of your choice do this trick.
1. Open google.com
2. Click on Change background image. it will open popup Select a background image for your Google homepage
3. Choose whatever background image you want to for google.com
Please Vote for this Tip if you found it helpful J
on Jun 11, 2010 | Computers & Internet
Background not lined up
The background i snot fitting the screen resolution so you need to stretch it. You might want to modify the background with a image editor to fit to your desktop or go with another back ground.
Aug 31, 2012 | Toshiba Tecra M2-S730 Notebook
Black background when scanning in greyscale
There is an option to set the brightness/contrast in the first page of Capturperfect. Select automatic if you cannot manually set it.
S. Mohan
Mar 29, 2012 | Canon DR-9080C Path-Through Scanner
What is the basic code for html code for background
HTML Background Code This article provides HTML background code - code for setting the background properties of an HTML element.
The following examples use Cascading Style Sheets (CSS). CSS is the best way of setting the background properties in your HTML. It's more flexible than the (outdated) HTML method (more on that below). Using CSS, you can set the background properties of any HTML element. Plus you can do things like, specify an image's position, whether it should repeat, how it should repeat etc.
Background Color You can set the background color of any HTML element using the background-color property. You can choose a background color with the HTML color chart.
HTML Color Codes Use this page to get HTML color codes for your website. The colors are represented by their hexadecimal values (the most common method for the web). On the color picker, you can also see the RGB values (you can use these for the web too).
Example of HTML color code usage:
To learn more about HTML colors and how to apply them to your website, check out the HTML colors section of the HTML tutorial.
Mar 16, 2011 | EliteGroup Computers & Internet
How to Add a Background Picture to a Microsoft Word Document 2007
t is easy to add a background picture by using the Watermark feature. First, you will click on “Page Layout”. In that menu bar (or ribbon), click on “Watermark”. A window menu will open. At the bottom of that window menu, click on “Custom Watermark”.
In the new menu that opens, check “Picture Watermark”, then “Select Picture” to find an image file on your computer to use. You have the option to have the picture look faded, as a watermark, or displayed in its full color. Check “Washout” for the faded option, or uncheck, to view the background picture in its full glory.
You will then need to choose the size of your background picture, by selecting one of the options under “Scale”.
To remove the watermark, simply click “Watermark”, and choose the “Remove Watermark” option.
Even if you don’t choose the “Washout” option, the background image will appear faded while you are working on your page. But, if you view the page through “Page Preview”, you can see how the background will look when printed.
To get to the "Page Preview" command, click on the button.jpgOffice Button on the upper left hand corner of the Word 2007 screen. Move your cursor over the "Print" option, and another menu will open to its right. On that menu, click "Print Preview".
Jul 21, 2010 | Microsoft Windows XP Professional With...
Want to use a logo designed in PhotoShop CS4 on Avery
make if a PNG file..its a possibility ..or if you want the logo on each page or in the background..insert it on the background feature as watermark....this will put it in the page ..and probably if the feature is available in this program you will have the possibility to either be like that or washed out ..
Apr 29, 2010 | Avery Design Pro 5.0 for PC
1/2" yellow line appearing in the middle of a background colored page
sounds like you need a replacement drum as it sounds like it is faulty, this is a replacable part and needs to ber replaced from time to time, this is a common symptom of this fault
Oct 03, 2008 | HP LaserJet 4600dn Color Printer
Unwanted color printing
assuming you are using a browser have you gone to file page setup and uncheck the background printing of colors.
otherwise we need more info
OS , software application used, usb /network printer ,model printer
any changes made recently. etc..
Apr 02, 2008 | Computers & Internet
Computers & Internet Logo
194 people viewed this question
David Payne
David Payne
